Question about Konica Minolta DiMAGE A2 Digital Camera
How was EVF improved? - Konica Minolta DiMAGE A2 Digital Camera
    Master:
  • 425 Answers
This camera is equipped with the TFT micro display which has about four times the resolving power (number of pixels) of past models. As a useful mode, it has "Quality mode" of 640x480 pixels (30fps) and "Motion mode" of 640x480 pixels (60fps). Quality mode: The high resolving power is the most important. The detail parts can be recognized, and it is helpful when the focus is checked. Difficult focusing on the past models can be easy without enlarging. Motion mode: It is for recording the moving subject. The same number of resolving power is displayed as the quality mode. However, as the pixels are interpolated from 640x240 to 640x480 in Motion mode, the image in the Quality mode looks better.
Posted on Sep 15, 2005
SOURCE:
How can I fix the button that turns on the EVF and turns off the screen? It isn't working.
sir,
I don't understand your question!! how can we use EVF for this model in which it is not fixed from the company, the tilting type LCD is very clear and user friendly in this model.
some old models comes with EVF there may be a small switch beside the EVF. and in some models comes the switching options in the setting menu. if your model is like that you try it in the S-menu.
Jan 10, 2016 | Sony Cyber-shot DSC-HX1 Digital Camera
View finder on my Sony HVR-Z5U isn't working, I can film through the flip out screen, but unable to use the eye piece view finder
POSSIBLY THE RIBBON CABLE THAT RUNS FROM THE EVF (VIEWFINDER) TO THE MAIN PROCESS BOARD SHOULD SWITCH REFERENCE TO EVF WHEN LCD PANEL MONITOR IS CLOSED REGARDS JOHN
www.jvsvisual.com
Mar 14, 2013 | Sony HVR-Z5U High Definition DV Camcorder
Have a fuji finepix S5600, but my lcd remains black even the camera is on! i can see the pictures i already made at the lCD. But LCD is not working if i want to make new pictures??
Hello, I think I know what the problem is..we'll see. On the back of the s5600 there is a button marked EVF and LCD(EVF on top LCD underneath) try clicking this button to see if your LCD screen becomes available, only one of these can be used at a time and the default for playback is the LCD screen. However if you have set it to EVF it will revert back to this format when you leave playback and try take new footage. I hope this helps and it is nothing more complicated. I have some problems myself and know how it feels. Alan
Aug 29, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
LCD screen won't come on when camera is on. Does this mean the backlight needs to be repaired. Brand new camera!
Does the electronic view finder (EVF) work? Of course you tried toggling the EVF off so the screen would come on right???
Jan 31, 2010 | Kodak EasyShare Z1015 IS Digital Camera
EVF is dead
It's a known issue with both the A1 and the A2, and is caused by very poor design of the strain relief to the flexible circuit board which eventually cracks. If you open the EVF you'll see a small piece of blue or yellow tape on the pcb just where the damage occurs: this was clearly Minolta's pathetic attempt to prevent the problem.
There is effectively no fix for this as the only way ro repair it is to replace the pcb and to keep costs down Minolta made the EVF flexi pcb an integral part of the entire pcb which snakes it's way deep into the camera. If only they'd redesigned it as a separate replaceable section then things would have been easier. You'll notice that Minolta omitted the tilting EVF from the successor to the A2, the closely related Dimage A200.
The best you can attempt to do is to peel off the rubber eyecup (it has a tendency to tear, so be very careful) and then remove the two screws from the underside of the EVF. You'll then see part of the EVF pcb. Note that there are actually two pcbs layered together, one does have a joint in it, but sadly it's not the one which has broken. You'll see a red and a black wire connecting to a plug which attaches to a socket mounted on a side spur of the broken pcb. The blue or yellow tape I mentioned earlier will be stuck to this spur (ignore the second piece of tape right near the EVF lens). Now set the selection switch to the EVF position and turn on the camera. By carefully and gently manipulating the broken area (the break is usually microscopic, so don't expect to see the damage) you can usually achieve a position where the EVF lights up. You may need to apply more tape or some folded paper packing beneath the pcb to get the EVF to remain illuminated, and usually will need to give it umpteen attempts so be patient. When it stays illuminated, reassemble and gently fold the EVF back down. You'll often find that you have to repeat the job a few more times as the action of moving the EVF back down upsets the "repair". Once it's down, and the fix appears to be stable (i.e. it doesn't black) out or blink every time you touch the camera) then carefully glue the eyecup back on and use your preferred method to stick the EVF in it's parked position. I use thin double-sided adhesive foam jointing tape: if you live near a modelling shop or know a radio control modeller, ask for a piece of thin servo tape.
The bad news is that this repair will not last and that you'll have to either learn to love the LCD panel or resign yourself to regular re-fixes, but eventually the damage progresses until beyond repair. For the same reason, if you replace it with a used example, go for the A200 instead. It has the same lens and many of the same features as the A2, although ditches many of the useful manual switches in favour of menu-driven settings.
If you are lucky enough to actually obtain a complete and unused flexible pcb then expect three things: 1. it will cost more than the camera is worth; 2. it will cost far more than that to have it fitted; 3. it WILL fail unless you stick the EVF down permanently as Minolta never revised the design. You probably won't find the part though as Minolta pretty well exhausted the spares supply whilst making repairs under warranty.
The same fault occurs to pretty much all cameras which have articulated displays, whether EVF or LCD and is why top-spec cameras aimed at professional users omit this feature. Pro's want reliability and give their gear a hard time, so articulated gadgetry is a liability.
It's a real shame as the A2 was otherwise my near-perfect all-rounder. In my case I only encountered the problem after buying a broken A2 for spares (just for the rubber eyecup and a few minor parts) and just a few weeks after investing in the rare, expensive and vital BP-200 battery grip. I've stopped using mine altogether now as I simply cannot get to grips with composing on an LCD panel.
Sorry this isn't all good news, but hopefully you'll find my posting to be of use and will be one of the lucky ones whose DIY fix lasts. Feel free to ask me for further advice and please don't forget to rate my answer.
Jan 29, 2010 | Konica Minolta DiMAGE A2 Digital Camera
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
MY Hvx 200 Is totally Black when I turn it on. the display and playback of my old footage works fine but the picture is totally black. any Ideas When I switch the camera on, the view finder is totally...
You should go into the menu, camera settings and set the evf to on. EVF stands for electronic view finder. This can be set to be on when the lcd is open or closed. CAreful, if the evf is set to on and you point the viewfinder towards the sun, it will burn white marks into the viewfinder and ruin it.
May 09, 2009 | Panasonic AG-HVX200 Mini DV Digital...
What is the number of pixels of the EVF?
The ferroelectric 4.8mm (0.19 type) reflective micro LCD adopted for DiMAGE 7i's EVF has approximately 220,000 pixels.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
F707 Problem w/EVF and LCD screen
From your description, it sounds like what I've seen described by other people when something has come loose inside-- maybe a cable. If you do a search, I know there are posts where [crazy] people have pried open the guts of their cameras and have written out a step-by-step tutorial on what's in there. If you didn't feel comfy going that route, you might be able to send it to Sony for repair. My vote, if the camera works okay otherwise, would be to just live with it.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
70 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
