Question about JVC GR-D250 Mini DV Digital Camcorder
Can't zoom out
Yes I did, but it's still same problem, how about zoom motor at lense or control zoom button
  • 2,794 Answers
Try the control zoom button. See if it's sticking or
Posted on Sep 04, 2008
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
I have an old Canon TV zoom lense J10X10REA(DC) 10-100mm 1:2.3 This motorised lens is controlled by a 4 pin plug with 4 wires (red, black, white, green) leading into the internal motor control circuit...
You can test the motor connections using two c batteries in series (3v). Simply connect any two pins with the + and - ends of the batteries. Watch the pins position, which motor and direction of the motor operation. Make a chart of the polarity and the pins used. Go ahead and use it. most of these motors use less than 4 volts to move.
Mar 22, 2010 | Cameras
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Nikon zoom nikkor 35-70mm lense zoom is stiff.
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Dec 28, 2009 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
Feb 23, 2009 | Sigma f/NIKON- 28-90/3.5-5.6 Aspherical...
Distance scale does not move on canon efs 17-85mm lens
Yes, this is normal. Some zoom-lenses adjust the focus when zooming, to always keep the subject in focus. Those tends to be the more expensive lenses.
So you don't have to worry, nothing is wrong with your lens.
/Chris
Jan 10, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
Sep 30, 2008 | Quantaray Zoom 100-300mm f/4.5-6.7 for...
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Lenses
Focal Lengths for the C-2000/C2020 Zoom Adapter CLA-1 Step-Up Ring F/L+1 +1.6X +2X 2.5X B-Macro Yes Yes (43-55mm not incl. w/lens) N/A N/A N/A N/A B-28 Yes Yes (43-55mm incl. w/lens) 29mm N/A N/A N/A 1.45x 150mm Yes Yes (43-46mm incl. w/lens) 150mm 245mm 300mm 375mm
Sep 01, 2005 | Olympus Camedia C-2020 Zoom Digital Camera
Open Questions:
Audio drop out and/or static sound Thanks to anyone who has taken a look at my issue with audio cutting out. JVC has always been a brand I have confidence in, and I believe I picked this camera up when those recording to an internal hard drive were out of my range. Last summer, I received a fantastic deal on some JVC Evarios, so GR-D250 duo would be used only as back-up, BUT, I have a ton of old Mini DV tapes -- never recorded over anything. I would find the heads needing cleaning solution highly unlikely. The first 250 recorded the bulk of those 150 or Mini DV's and worked like a champ. Because of legal depositions for lawyers and like, who may not want for me to call time-out in a deposition to switch tapes and the fact that eventually my first was going to give out, having a back-up and eventually multiple seemed like the thing to do. Having a couple of friends film some sports events I could my mix radio play-by-play I could with dual camera angles was cool. This same-year model second buy had sat in storage; The original tape the who sold it to me with 10 minutes of footage came with it. I could tell the battery was so much stronger after a full charge than my old one, but this newer D250 has maybe had 1/10 the recording time as my original. Whether listening to the camera speakers, piping the sound from the rear A/V jack or importing via firewire, it's the same. The video may not be perfect and may "spark" or "flicker" in unison with the audio that drops out,but not always. At times, the video seems just fine but the audio drop-out is akin to a loop and I could probably time it, which was what I termed as cyclical. Could one of my friends have dropped it or tipped over a tripod and not told me? Sure, but I would think they would have told me. One night, follow some high school hoops I was importing, excited at the prospects of some two camera angles mixing. Thought I may have had a bad tape, but ruled that out right away through trying multiple tapes in bother cameras. Apologies for my loquacious follow-up; I suppose if worse comes to worse, I could check eBay for a secondhand model. I've "misplaced" my original, but it will turn up; it's simply a matter of desiring to import all that footage, since 2008, with superior editing software and skill than what I possessed when doing so initially. Thanks so much!
Apr 13, 2014 | JVC GR-D250 Mini DV Digital Camcorder
See all JVC GR-D250 Mini DV Digital Camcorder Questions
JVC GR-D250 Mini DV Digital Camcorder Logo
65 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
