Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction in wand only
Could no suction in the wand be caused by anything else? And how do I replace this part?
  • 25 Answers
Posted on Sep 06, 2008
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at
Kind regards
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Wand lost suction
cleaning all filter Assy and all Handle Assy and Hose Assy...
Nov 06, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
The wand does not have much suction
Here is a link to a YouTube video that walks you through the steps to check for obstructions which may cause your low wand suction problem. If you are getting good suction from the vacuum itself, an obstruction between the motor and the wand head is the most likely cause of your problem. The unit being used in the video is a DC04 but applies equally as well to a DC7 or DC14. Here is the link:
Hope this helps. If it does, please leave feedback! It is the only way I can tell if I am being of assistance or just wasting my time.
Oct 10, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My DC17 hose has no suction and is constricting
You have a blockage in the wand - take the wand off of the back of the machine, separate the wand from the hose by pushing the red button where the hose is attached to the wand. Hold the wand up in the air and look trough it. If you don't see light coming through the other end you have a blockage in the wand. Take a long object like a stick or a metal hanger and remove the blockage. I am confident that this is where the blockage is but...if you can see through the wand the blockage is in the u-bend, but the hose won't constrict then...remove the u-bend which is attached to the vac at the bottom next to the long gray hose - it is attached to the machine with a plastic screw - turn the plastic screw 45 degrees anti-clockwise and clear the blockage from the u-bend.
Jul 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
I am not getting any suctio out of the wand.
i had same problem it was discovered on the bottom o the bin thats collects dust was cracked and needed replaced this caused me to loose suction
Aug 30, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
If the wand alone causes a suction loss, there are only a couple of issues:
  • leakage
  • blockage
If it is leakage, remedy the defect or install the wand correctly.  If it is a blockage, you'll have to find and remove it.
Jul 14, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
