Question about Boss Riot 850 Car Audio Amplifier
Heellpp okay i was driving and my system was going loud as usual and it went out no sound i got off and checked the protection light was on and i turned off the car and turned it back on he green light came on the woffers came on only one sound came out and the protection light came out so i did it again and the protection light came on any ideas>> thanks
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Posted on Sep 07, 2008
How to fix my Worcester green star ri boiler?
The gurgling sound sounds like you have gotten air into the system. Try purging the air out at the bleeder valves. Also check and make sure that your water inlet is working.
May 29, 2016 | Water Water Heaters
2004 mustang driving home battery light on dash flashed on and off a few times, when stopped for a long red light, battery light came on again and so did the ABS light along with a very loud buzzing sound...
Hey Lg,,
Have your battery/alternator checked at a battery/alternator shop... you may have a loose connection or one or the other is going bad..??
Aug 29, 2017 | 2004 Ford Mustang
Hi i just put petrol in my subaru impreza 97 sport model as usual,and i started the car and i heard a loud bang noise coming from the exhaust the car made a loud ticking noise from the engine like a...
Sounds like your timing belt went bad.....HAVE IT CHECKED NOW>>>AND DO NOT DRIVE IT ANYMORE AS YOU MAY CAUSE FURTHER DAMAGE TO YOUR ENGINE.
Dec 12, 2009 | 1997 Subaru Impreza
Overdrive light and airbag/abs lights flashing
Sounds like an ECM going out. The systems being effected are not related and usually only connected though the ECM. Have it checked at the dealer.
Sep 10, 2009 | 2000 Nissan Maxima
My amplifier turned off while playing and wont turn on at all now
Hello, it sounds like you shorted the outputs of your amp or the power supply mosfets shorted. Very common when people have the music at a loud volume. Does the protect light come on? If not then the power supply is probably shorted not letting the protect circuit get any voltage. Some amps do this and other amps if the power supply shorts have the protect cicuit built in such a way that if the power supply shorts out the protect circuit still works. Cause you checked all wiring and redid it and no fuses blew then this is your problem. I repair amps everyday for a living. ?Most of my out of state customers are from fixya.com. I'm the cheapest amp repair business you'll find. If interested send me a private message letting me know what kind of amp it is, name and model number, and i'll get you back up and running with warranty.
Aug 23, 2009 | Car Audio & Video
I ave justed had the engine light come on in the car, the car seems to be driving okay but jumps in and out of limp mode. any ideas?
In some cars, depending on what caused the check engine light comes on, it may cause the engine to reduce power in order to protect the engine. This sounds like the symptom will start and disappear at times causing your car to go in and out of limp mode
Aug 11, 2009 | 2008 Saab 9-3
Very loud sound when driving as though muffler not functioning. Drivability okay otherwise. Service Dept can"t see me for a few more weeks and not sure if it's safe?
You should be okay for short trips . I think the muffler went out has a hole or leak.
The noise is going to get louder and louder if it is the muffler.
Jul 19, 2009 | 2005 Mini Cooper
Samson sx1800 power surge
Hi There,
Manufacturers install protection devices in their audio systems that are there for that purpose, any loud 'thump' or 'crack' trips the protection device so the loud speaker wont be burnt out. Speakers are expensive so the manufacturer does his best to allow you to listen to very loud sound and yet provided protection in case you exceed the sound rating of the output protection device.
In your case it sounds like the protection device has done its job but has not reset, to allow more listening...
Check the operational manual that came with the amp system to see if there are re-set instructions available to you....
If you dont have the reset detail, then phone/e-mail the manufacturer to obtain the reset information...
If there is no resetting you can do as a consumer then it should be no problem for a service shop to do the reset for you...
It may be a simple internal fuse that has blown but if its not accessible from the outside then I dont suggest you go inside and make changes unless you are skilled and trained in electronic servicing...
Cheers for now YUBEUT
Oct 31, 2007 | Samson SX1200 Amplifier
Boss Riot 850 Car Audio Amplifier Logo
129 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
