Televison & Video Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Anonymous
Level 3:
Guru:
  • Master 586 Answers
  • Posted on Aug 10, 2011
Anonymous
Master
Level 3:
Guru:
Answers
586
Questions
0
Helped
211816
Points
1670
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required I NEED SONY BRAVIA T32 - arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DI NEED SONY BRAVIA T32 - cnn_dvi.jpgsrc="/uploads/images/cnn_dvi.jpg" alt="cnn_dvi.jpgI NEED SONY BRAVIA T32 - l.jpgss="h_mi" /> Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture I NEED SONY BRAVIA T32 - cnn_composite.jpg src="/uploads/images/cnn_s_video.jpg" alt="cnn_s_video.jpg" class=I NEED SONY BRAVIA T32 - cnn_coaxial.jpgure Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Can I replace LCD screen on my 32 inch Sony Bravia KDL with screen from my Samsung LN-t32?
You can replace it. Contact the authorized service centre for Sony. Sony won't sell it at open electronic spare part market. The cost of the screen + Service charge might rise up to 2/3rd of the total cost of a new TV. Gopakumar Gopalan Google
1helpful
Connecting to sony bravia tv via mini hdmi cable
go to settings-connectivity and follow the option you wana go for
1helpful
Is freeview available on a bravia 32 inch kdl 32l 40xx television please thankyou
Hello Keith,
Yes, it has a built-in DVB-T* tuner which is what you need to tune Freeview channels. It also has an analogue tuner if required.
* Digital Video Broadcasting - Terrestrial
You can view the full specifications for this model by clicking on the link below and you can download a user manual from there if you need one.
http://www.sony.co.uk/product/t32-l-series/kdl-32l4000/tab/manualpopup?section=ODW+SS+en_GB+Support+New&externalUrl=ftp%3A%2F%2Fftp.vaio-link.com%2Fpub%2Fmanuals%2Fconsumer%2FKDL-32L40xx.pdf
If you already own this TV and are unable to receive or tune Freeview channels, please let me know and I will be able to assist you with this.
Hope this helps
Regards,
BElectric
3helpful
2answers
Manual for a Sony Bravia TV
Here you are:
http://www.sony.co.uk/product/t32-nx-series/kdl-40nx703#pageType=manual
MANUAL FOR BRAVIA KDL-37V5810
Try to download manual from
http://www.sony.co.uk/product/t32-v-series/kdl-37v5810/tab/manual
Good luck.
Please rate the answer if you are satisfied. If not let me know.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
