Question about Sony KP-53HS10 TV
Please Help I'm having the same problem with my sony. I'm can't figure out how to get the speaker grill off. There are no screws at the bottom, the only screws I see are behind the mesh material. Please help, football season starts this weekend. You can email me directly at
It just pulls straight off. It has little posts on the grill with rubber grommets that holds it into place.
Posted on Sep 12, 2008
How do i remove the Sony MHC-EC98PI speaker grills?
Insert some sort of scrapper at bottom of speaker box where front grille and box joins and hit scrapper blade with rubber hammer to bring out grille because it is fixed very tightly with box.
Following images are scrapper and exploded view of speaker box that will help you.
Oct 27, 2010 | Audio Players & Recorders
I have a sony model kdf-e42a10 and I'm trying to replace my screen. However, I have removed all the screws for the top to the bottom, but can't find the bottom screws. Help please.
Remove front speaker grille block assembly as shown in below image then remove screws under that cover to take off front screen as rear screws have already been removed.
Hope this info will help you.
Jul 11, 2010 | Sony Televison & Video
How do I get the speaker panel off?
There are 2 Caps on screws at lower part of speaker grille that holds it intact.
See below image for more details..
Jun 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Remove Speaker Grille from Sony KP-65WV700
So you got the six screws undone, great! Now you can pop off the front speaker grill. The easiest way is to work your hand along the top and bottom to pop the plastic out of the "holders"
If what you are describing to me is the main wires still attached to the rest of the TV. So don't pull it out too far! If you do it right you won't have to unplug the wires, and save yourself some hassle... with this TV you'll have to pull it out JUST ENOUGH to get access to the carboard/masonite backing, removing such will give you full access to the six controls.
Adjust from there! Sorry for the wait, and I hope this helped out!
May 30, 2009 | Sony KP-51HW40 51" Rear Projection...
There are no screws on the speaker grill of this particular model
If it is KP-51HW40 Sony TV
Speaker grill has 2 caps covering 2 screws at bottom of speaker grill.
Below is an image showing caps of speaker grill that might help you to open it.
Feb 13, 2009 | Sony KP-51HW40 51" Rear Projection...
Removing the speaker grill from my Sony KP-53HS10
There are two screws (1/4 in. philips) located in the lower left and right front of the cabinet near the floor. They may be concealed by a plastic overlay. It can be popped off with a small screwdriver.
Be careful!
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Open IM600 docking station to look inside player
YPMDesign is correct, but to get further into the im600 you have to peel off the cover that masks the LCD (it has Altec Lansing printed on it). Once done, it exposes 2 screws, and when removed you can pull open the whole thing, exposing the main circuitry. There is nothing that can be reseated though, as all appears soldered. There is one main board, which everything connects to, then the PCB at the bottom of the system, which has the power buttton and ipod dock connector etc. Unfortunately I have been unale to resolve my problem, where the Power buttton LED lights briefly if the battery is removed and reconnected, but getting nothing on the main display, and the power button is not responding at all when depressed. Mine is sadly bin bound..
Oct 19, 2008 | Altec Lansing Inmotion-IM600...
Help with lines in screen
At the bottom of the speaker grill there are two holes filled with a plastic plug. Use a small flat head screw driver on the sides of the plug to slide the plugs out. You'll see the little space next to the plug on either side that you can put the flat head in to slide the plug out. Once you do that there are screws behind those plugs. You'll need a phillips head to take those out. Then just pull out gently at the bottom of the speaker grill and it should come toward you then just slide it down a little and it comes right off. Behind that is the particle board screwed on in the center with several screws. Take that off and you can't miss the adjustment blok.
Jul 02, 2008 | Sony KP-51HW40 51" Rear Projection...
How to remove the front speaker grills on a sony kp51hw40
This set has two small plastic caps located on the front panel near the bottom. After you remove the caps you will find two screws behind them.
Jan 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
