Just set up a samsung 67in hdtv--all is fine except the image is cropped at top and bottom regardless of the picture setting at 16:9 or 4:3 or wide or just scan which should adjust the signal sent from cable box--its as though it is not sending an image meant for a 16:9 aspect--any suggestions--could it be the cable box a scientific atlantic hdtv dvr--any help is appreciated--joe
  • 4 Answers
We have the 61" Samsung. WE LOVE IT!!! We have a DirecTV DVR box. On the DirecTV remote there is a "format" button. It cycles through all the different options. (Pillar Box, Stretch, 720p,1080p, etc.) Adjusting the picture setting with the Samsung remote is not the same thing. Try using the cable remote......see if it works the same as mine.
Posted on Sep 04, 2008
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Dec 20, 2010 | Panasonic TH-42PX20U/P 42 in. HDTV Plasma...
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
Picture is cut off top and bottom (Infocus 7210 projector)
try different ratios, also reflash firmware and lastly try new cables.
Jul 14, 2010 | InFocus ScreenPlay 7210 Multimedia...
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
Jun 22, 2010 | Dell Dimension 8200 PC Desktop
Why did my picture become big so I can not see the sideline information
Press the RATIO button repeatedly to select the desired picture format. You can also adjust Aspect Ratio in the OPTION menu.
  1. Set By Program. Selects the proper picture proportion to match the source’s image. (4:3 → 4:3, 16:9 → 16:9)
  2. 4:3. Choose 4:3 when you want to view a picture with an original 4:3 aspect ratio, with gray bars appearing at both the left and right sides.
  3. 16:9. Choose 16:9 when you want to adjust the picture horizontally, in a linear proportion to fill the entire screen.
  4. Horizon. Choose Horizon when you want to adjust the picture in a non-linear proportion, that is, more enlarged at both sides, to create a panorama view.
  5. Zoom 1. Choose Zoom 1 when you want to view the picture without any alteration. However, the top and bottom portions of the picture will be cropped.
  6. Zoom 2. Choose Zoom 2 when you want the picture to be altered, both horizontally extended and vertically cropped. The picture taking a halfway trade off between alteration and screen coverage.
  7. Cinema Zoom. Choose Cinema Zoom when you want to enlarge the picture in correct proportion. Note: When enlarging or reducing the picture, the image may become distorted. You can adjust the enlarge proportion of Cinema Zoom using D / E button. The adjustment range is 1~16.
Oct 18, 2009 | LG 42LC2D 42 in. LCD HDTV
The ticker tape during football or nascar is not visible
If your watching a standard resolution(4:3) picture in wide screen format (16:9). than the picture will be stretched and the tops and bottoms cropped. look in your video or set up menu to change the resolution settings to standard 4:3
Sep 27, 2009 | Mitsubishi WD-65731 65" HDTV
I have the same promblem
Sep 27, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Same issue here with this TV. Started when I hit auto converge
Sep 27, 2009 | Zenith R49W36 49" Rear Projection HDTV
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Picture crops at top and bottom of screen
I assume you have used the "wide function" on your remote to verify you are not in "zoom" mode? Other than that I can't be much help.. Sorry Roger
May 05, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
