SOURCE: Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
SOURCE: Acer Aspire T180 Frozen
Select the del and in bios, select optium defaults. next select F12, will it go any further?
SOURCE: wont turn on
He is getting the screen with del, enter , f12 so the power supply is fine it could be his bios battery that needs to be reseeated and factory default loaded. If you left it on for a while it could be in a state of sleep/hibernation and if you should it down manually you could have stopped it from resuming and thats why it wont boot now and by reseating the bios battery for a couple minutes could remove the resume from the computers memory and might fix your problem. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
SOURCE: Acer Aspire E380
Uw systeem erkent niet de harde schijfaandrijving. Het is zeer mogelijk dat sinds XP CD niet de harde aandrijving die de aandrijving zelf heeft ontbroken zal zien en zal moeten worden vervangen.
SOURCE: CANT INSTALL 64BIT PROGRAMS
64-BIT PROGRAMS runs on 64-BIT OPERATING SYSTEMS
The 64-BIT Processor has nothing to do with it, it serves a different purpose specifically, to the OPERATING SYSTEM.
