Question about Harman Kardon HK595 Computer Speakers
Harman kardon sub with no speakers
I have a Har Kar sub for a computer.
its 2.1 channels and i dont have a the speakers to connect to it.
the speakers have the on off control on them.
is there a way I can manipulate the pins where the speakers are supposed to plug into?
i know it is cheap to buy a new one, but this one was $3
  • multiball Dec 14, 2008
    sam here. What speakers will plug right into the sub?
  • Anonymous Dec 29, 2008
    Ditto. Bought the sub from Goodwill for 8 bucks. I'm thinking I will just bypass the chip entirely and wire the sub in on my own.
Benimur
  • 6966 Answers
SOURCE: Harman Kardon 595
Hi, probably two things that can go dead, 1) the woofer itself and/or 2) the amplifier. I will rule out poser supply cos the other speakers are working. Normally they have a separate amplifier than that of the woofer. If you are comfortable working with a soldering iron and a multi tester, after unplugging from the mains, then you open the enclosure and check the continuity of woofer which should read between 4-8 ohms, if it is open or no reading, replace just 2 wires/terminals involve with 3 or 4 screws. If the woofer reads a continuity, then it is the amp which normally is just a single power IC attached to an aluminum heatsink. In some instances, it may be a power transistor pair. In any case you have to be familiar with component level repair. Otherwise, you are probably better off asking a qualified service personnel to do the repair job. Hope this be of some help. Pls post how things turn up. Regards.
Posted on Apr 26, 2007
Open SKy
  • 620 Answers
SOURCE: harman kardon
Orastie
Wow, general problem here, but the most near your problem could be, power failure, or the Power adapter is bad, or a energy failure at home, time to buy a new adapter.
Carl
Posted on Dec 30, 2007
whitebirch
  • 433 Answers
SOURCE: i need connection instructions, please
http://www.harmankardon.com/product_support/SupportDetails.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=HK695&sjump=ps&ky=295752998DFB844994AFB5150B637833&#active
Here is the info you need to connect, manuals, troubleshooting, drivers...And instructions.
Please leave rating
Posted on May 03, 2009
billfox1966
  • 231 Answers
SOURCE: removing cover from speaker
pull off the cloth cover by using your nail or a screwdriver to get behind it. its simply a push fit cover.then you can acess the screws. there are 4 deep in the holes where the cloth covers connected to the speaker and there are 4 holding the actual speaker to the face that are plainly visible once cloth front cover is removed.
Posted on Jul 24, 2009
SOURCE: taking apart harman/kardon subwoofer
turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I am getting no sound from sub. The turns on, but so sound. I have connected to two different receivers to verify it isn't the receiver sub output.
Bear with me on this.
Just because two systems don't light this sub up doesn't prove the amps are faultless unless they work with other subs. Can you assert that?
See page 14:
http://www.retrevo.com/support/Harman-Kardon-HKTS-14-Speaker-Systems-manual/id/386ci056/t/2/
How are you driving the sub - Speaker or Line Level?
Jan 30, 2011 | Harman Kardon HKTS 14 System
Can not get any sound out my harman kardon speakers when i connect to my mc pc
call apple they will give a $50 credit and if they dont work they will send you working speakers
May 08, 2010 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon Sound Sticks Sub Problem
Oh well, buy new ones. What are harmon kardon sticks anyway?
Mar 09, 2008 | Harman Kardon Harmon Kardon SoundStick II...
Hearing a simple low frequency cycle up to a mid frequency over 4-5 seconds
Hello stocker
Happy Holidays
well, it is a bad capacitor on the sub, you have 2 options here, if you got warranty, go ahead and RMS your sub, or get it to repair it center to a repair.
good luck
Dec 22, 2007 | Harman Kardon HK695 Computer Speakers
Sound sticks II
My problem is fixed now. I plugged the speakers into the earphone socket. There was no immediate effect just silence. I twiddled the control on the bass unit, played with the volume controls on the sticks. Then I realised the sound was back with the external speakers not the internal ones. It was as though the Harman Kardon system was re-booting itself. Very weird.
Dec 05, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon HK595 Computer Speakers Logo
208 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
