Question about Vacuums
How do you replace the belt on a Hoover Savvy?
  • Ltaboy Jan 17, 2009
    The belt to my Hoover Savvy broke and I bought the replacement. Now, how do I go about replacing it?
    President:
  • 1,673 Answers
Take off the bottom plate, then remove the screws to remove the top cover, turn vac over, remove the hoover emblem, there is a screw there to remove. The top should come off, the easiest is to loosen the motor to give you some slack, then replace the belt and reasemble.
Posted on Sep 04, 2008
Replace belt on Hoover savvy vacuum
There is not a brush belt on your model. It has a drive mechanism that turns the brush rolls.
Feb 20, 2016 | Hoover U8145-900 Savvy Bagless Upright...
HOOVER VACUUM U8173-900
1) check the hose for blockage.
2) see the belt is slipin to due worn and replace .
3) check the bag/tank for full and need empty, and replace.
However go to the
http://hoover.com/support/video-instruction-guides/
and use the troubleshooting with common senses.
God bless you
Sep 06, 2012 | Hoover U8171-900 / U8172-900 / U8173-900 /...
How to change belt on hoover savvy vacuum
How do I change the smaller brush belt on a Hoover Windtunnel Cyclonic?
Jan 11, 2010 | Hoover U8145-900 Savvy Bagless Upright...
Roller bars on bottom not rolling
The belt has probably broken. Hoover says that the belt on this model should last the life of the vacuum, but that is rarely the case. They do wear and break. Changing the belt is simple and the belts aren't to much. You can get a replacement here:
Savvy Replacement Belts
Oct 30, 2009 | Hoover U8145-900 Savvy Bagless Upright...
How do I install the timing belt on my Hoover Savvy Vacuum? Modle # u8174-900 Where is it located?
http://www.vacshopusa.com/hoover_savvy.htm
This is a parts schematic for your hoover savvy. You have to take off the brush guard on the bottom and also the cover on top (there is a screw under the round hoover logo). You will then see how the belt is attached. Very easy to do. Hope this helps
Jul 02, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
U8174-950 SAVVY BEATER BAR NOT TURNING HOW DO I REPLACE BELT OR FIX BELT AND WHERE IS CLOSE SUPPLYER IN EDMONTON ALBERTA
Take the screws out from the plate covering the brush roll, look for maybe 2 screws from the bottom to take out, then turn vac over, remove the Hoover emblem and remove the screw there, now the top will come off and you can get to the belt and brushroll. Check around your local repair shops for a cogged belt for the Savvy. I would think someone would stock it. Alot of Sew and Vacuum stores also service and have parts.
Jun 10, 2008 | Hoover Vacuums
Hoover US8174-900 Savvy Bagless
It uses a cogged belt, turn it over, remove the bottom plate, remove the other screws from the bottom, turn vac back over and remove the Hoover emblem, there is a screw there to remove and the top comes off, then you can get to and replace the belt.
May 26, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
Sep 01, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
