My daughter dropped my camera and it is not working. it is not turning on and not taking pictures, the zoom part is out all the time
someone dropped my camera now when i try to zoom it make a loud beeping noise and shuts off.plase help. i have a digital samsung.
As has been explained many times, dropping a camera damages it. Damaged cameras do not work. They are what is technically known as 'broken'. You will have to get it repaired.
You may want to call Olympus Customer Service as this is probably a repair issue with the camera. They will be able to explain their repair policies and procedures to you. Their telephone number is 800-622-6372 option 2 and then option 3.
The lens got out of track. Try to have them back by forcing gently the lens in ou out with your fingers. If they are bent, force them straight. Hope it helps.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Lens unit has to come out to see whether the problem can be sorted out without spares going in. But unfortunately you have to go from the back on this model which means disconnecting and removing all 3 pc boards and the LCD screen and then loosening the lens mounting to slide the lens out from the back.
You may have to dismantle the free lens further once it is out to see exactly what the damage is ( if any ).
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
In any case it could not make it worse
that is a symptom of being dropped and stuck in a mode. it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
