Question about Philips Magnavox Learning Universal Remote
Can no longer get to "menu" screen on Magnavox tv
Have a 15yr old Magnavox tv, model# RS1966 B421.  My remote is able to turn the tv on/off, change channels, but the "menu" key no longer works.  The "menu" screen no longer is displayed, so we can't add/remove cable channels, switch from cable input to video input, etc.  Do not believe the issue is the remote (replaced the remote and saw the same problem).  It was working a week ago when we left on vacation and wasn't when we came back.  The tv itself has little in the way of manual controls; power, channels, volume (and a couple display and status buttons that don't seem to work).  Any ideas on how to get the "menu" display working again?
SOURCE: Controls not working on Philips 28" TV
We had this problem with a 28PW6515. The control would work for 30 seconds after switching on, then nothing. It was diagnosed as the "glue chip" which handles all the control functions. About £200 to fix it as it's a surface mount chip.
Posted on Jun 22, 2007
  • 317 Answers
SOURCE: Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Posted on Sep 11, 2007
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
leecom72
  • 4806 Answers
SOURCE: TV won't work with any remote control
you have to reprogramme the remote, here is the offical site with instuctions and codes for your device:
http://www.universal-remote.net/philipsmagnavox.html
regards and dont forget to rate us!!!!!
Posted on Nov 27, 2008
SOURCE: magnavox 26md255v/17 no responce to any remotes
lo que quiero es una buena verga!!! Me llamo Martin Antelo, Soy *** pasivo boliviano, mi cel (+591) 70844331, y mi email martin_antelo@hotmail.com agregame ahoringa y llama... te espero
Posted on May 17, 2009
Magnavox model # FP4630 W104 manual
GOOGLE THE MODEL NUMBER WITH MANUAL AFTER IT IF YOU NEED THAT.
In the TV menu make sure under audio speakers are switched on.
When you try to change the volume do you get a display on screen?
If the vol buttons on set work the issue is with the remote itself.
Let me know as much as you can so I can help
Mar 16, 2012 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
I have Magnavox television model number TP2770 C101 when I turn it on it goes to the start up menu and I do not have the remote. how do I get to the regular tv mode? Read more: I have Magnavox television...
There may be a way to get to the audio and video without a remote by first pressing the menu button on the front of the set (if there is one), but the easiest fix is to invest in a good universal remote which will allow you to open the full TV menu. From the start up menu the remote will, after matching the code, allow you to go deeper into the start up menu to the audio/video menu and on to the "regular TV mode".
Jul 28, 2017 | Philips Magnavox Learning Universal Remote
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
Philips 50" flat screen - Closed captioning won't turn off
on my magnavox it was the verizon fios remote that enabled it by accident (it is tuned to control the tv) however it was a cc button represented by the * on the remote that i had to select to change the cc. this didn't make it go away so i just pressed buttons i used the "Aspect" button represented by the # it changed the ratio and the message went away. I usually only use the fios remote to turn the tv on and off but this must be some whacky override that comes from the fios remote.
Jan 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No remote how to turn off cc
You might try a Magnavox brand universal remote. Get one with a "menu" button. Often they give nearly complete control on a Magnavox brand TV. Otherwise, the only real solution is to purchase the exact original remote. There are many vendors on the Internet selling replacements, but often the costs are ridiculous.
Jan 23, 2009 | Televison & Video
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox Learning Universal Remote Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
