Question about HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
My HP Color LaserJet 2600n has been having printing problems lately.  The magenta and blue cartridges were running low, so I replaced the cartridges, however, it never seemed to work right after that.  Occasionally for black and white it would be ok, but then each page started having vertical magenta streaks on it and not all the color was coming out.  So I replaced the remaining cartridges and still the same thing.  Now, with the new black cartridge, the black won't print across the page and most pages other than the test page are covered with magenta.  The black will only print about 1/4 of the way horizontally and fades out.  Can you help me diagnose the problem or is this a job for the technician?  If so, how do I find someone to service it?
  • 300 Answers
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Posted on Sep 04, 2008
Hp CLJ 2600n colors problem
do a permanent storage init reset
Feb 13, 2014 | HP Color LaserJet 2600n Printer
Print blurring
you have to clean the lsu. laser unit. you will see there is a lot of dust on the bottom mirror inside. it is a big job. advice that you must be tecnical.
Feb 29, 2012 | HP Color LaserJet 2600n Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n problems
changing magenta cartridge wont solve this problem.
You have to visit HP sevice.
They have to clean mirrors inside LS assy and this will fix your problem.
P.S. For more info follow this
Apr 28, 2010 | HP Color LaserJet 2600n Printer
Hello, I have HP lj 2600n. It does not
the problem is due to scanner mirror have to clean the scanner mirror.
Oct 26, 2009 | HP Color LaserJet 2600n Printer
Lines across printed page
try to locate the print head of the unit. you will see a mirror there. clean the mirror maybe it has some foreign object.
Jul 04, 2008 | HP Color LaserJet 2600n Printer
Magenta cast over whole page
Jun 22, 2008 | HP Color LaserJet 2600n Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
Jun 09, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
592 people viewed this question
Ben Johnson
