Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
GARAGE DOOR My garage door opens with a lot of noise and stalling.
    New Friend:
  • 59 Answers
Two things to check...use the disconnect handle where it attaches the door to the opener, then see if the door will open manually easily, if it does, the door is ok, if it doesn't LOOK at the springs that raise it. DO NOT try to adjust the springs yourself!!!!! if one of them is broken, call a service Co. to handle the repair. Also, check if the door is level. an easy way to eyeball it is to look at the rollers in the track while the door is closed. they should all be the same distance between the hinge on the door and the track. NEVER TRY TO MESS WITH THE SPRINGS!!!!!! THEY CAN SEVERELY INJURE YOU!!!!!!!!!!!!
Posted on Sep 05, 2008
Garage door stalls
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Opener: doesn't move the chain; the motor makes a rotating noise for a while and stops, but no movement visible at the chain
Take off end panel opposite logic board. Should contain light bulb. Look inside. See lots of white powder? If yes, you need to replace gears (About $30 kit) . If you are pretty handy , you can do it. If not, replace entire unit.
Dec 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 3 stall garage with two garage doors, we also have 3 garage door openers. When I push the button on one opener both doors open or close. How can I fix this?
You will need to clear the memory of both openers by holding the smart/learn button in for 6 seconds. After doing this none of your remotes will work but your wall control will. Now you need to program the openers making sure you don't program any remotes for both doors.
Dec 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
After the door is fully open, the motor stalls when closing. It trys to continue to open instead of close and the screw drive carrage jams against the "open" end and stalls. I have to unplug it to get it...
It sounds like you have a broken or missing "upper limit switch". There is one for the down limit and should be one for the upper limit. If it is defective or missing the openers 'brain' will not tell the motor to reverse direction.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener - Gears need to be fixed
Unplug the unit and remove the cover, usually eight screws, if you see a lot of white dust in the cover check the nylon drive/worm gear, they will need to be replaced.
Apr 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2HP garage door opener making noise but not opening
TIME TO REPLACE THE GEAR KIT PARTS ARE AVAILABLE IF YOU ARE A REASONABLE MECHANIC IT IS A DOABLE REPAIR - FOLLOW THE INSTRUCTIONS!!!!!
Apr 09, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Dec 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
93 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
