Question about Intel D945GTP Motherboard
Dead MB? Have a D945GTP system that has been running for some time. Unplugged it for a few weeks. Now, there is nothing when you turn the power switch on. Have the green LED on the MB when AC power is ON. While AC was on, I replaced the coin cell battery. Old one was 3.0 volts, seems OK. Still nothing. With new coin cell in place, replaced power supply. Nothing. Any suggestions would be great.
  • 1 more comment
  • wpbrown18 Mar 22, 2009
    plugged in new power supply. Power supply fans don Hunks. unplugged connection to 242 CPU core connector-power supply fans work. any idea of problem-should i replace motherboard
  • Rage535 Apr 28, 2009
    Similar problem here. I can hear hd/cd drive pwr up. all fans working. no external outputs. (no light on usb keyboard, mouse) no vga. I do have lights on the onboard nic. But cannot ping machine, or remote into it.
    have tried swapping ram, drives, etc. did not try swapping pwr supply.
  • highrthangod Apr 28, 2009
    My computer was working fine. At the time, I had created a new folder and was transferring some files from another folder into the new one I just created, when all of a sudden, in the middle of transferring a file, the computer lost all power. As if someone just pulled the plug out the back of it. I see the green light on the mb is still on but won't power up. At all. I've changed power supplies. Still nothing. I take my hd out, run it as a slave on another computer and it works fine. So I'm left with the possibility that its either my processor or the mb that doesn't work anymore. I think its the mb but dont understand why.
Most of the time the issue seems to be a bad power supply. I would test with a different one if possible. In rare cases I have seen the capacitors bulge and leak leading to a dead motherboard.
Posted on Sep 04, 2008
Hearing a buzzing sound at start up.
I think that your PSU is dead and your motherboard must be dead too (not sure)
Dec 16, 2012 | Computers & Internet
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
D945GTP comes out of standby automatically
Check out all of your power options. Also make sure that none of your keys on your keyboard are stuck or mouse buttons. If anything touches yoru keyboard or mouse, it will come out of stand by.
Nov 30, 2008 | Intel D945GTP Motherboard
Computer is not working, changed power supply and is sti dead
Try to unplug the power cable from the system for 2 minutes and then turn the PC on.
If that does not work, then look for the battery of the motherboard, it would be like a coin. Use clippers and remove it for 2 minutes and put it back in and power the system.
If that does not work then try and remove the one RAM at a time and restart your system.
If all the above steps does not work, then you would have to replace your MB.
Aug 22, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Won't boot up
We cannot assume that your motherboard is dead, try these: Unplug computer power cable from the socket outlet.
First, check to be sure the power supply is switched to 120 V.
If it is, then do a minimum system configuration test. Turn off the ON/OFF switch on the PS back panel, and disconnect the cord. You don't want to work on the motherboard (MB) with standby power applied.
Disconnect all components from the motherboard (including floppy, CD, hard drive). Leave the power connector attached to the hard drive, as the power supply has a minimum load requirement (never run a switching supply without a load, unless it is designed to do so -- and few are). Remove the power connector from the Motherboard, then reinsert it (potential for bad contact in control circuit).
Remove the RAM, reinsert one stick (going for a minimal configuration).
Remove all PCI boards and AGP. The motherboard should be able to turn on and beep an error code even without RAM and video.
Plug the PS back in, turn on the back panel switch, and use your screwdriver to short the power button pins (ATX type of supply).
Double check which pins are the power switch pins in the documentation, as front panel attachment point functions are usually not obvious, and are easily mis-wired since the connectors come off so easily during maintenance.
When you touch the pins, the CPU fan should instantly start turning, and shortly thereafter, the MB should beep an error code.
If not, check the mounting for the MB. Some cases use a U shaped rectangular snap in receptacle for MB mounting screws. These commonly become bent or twisted, and can short out nearby traces sometimes resulting in dead board symptoms.
If the fan didn't start turning when expected, you probably want to repeat this minimum configuration test with the motherboard out of the box.
Put it on an insulated surface (e.g. pink packing foam or cardboard), being careful about electrostatic discharge (ESD) (however, my bet is ESD damage that disables a motherboard is rare).
Although I haven't seen it, your motherboard may require the video card to be plugged in to turn on.
I doubt this, though, as there is enough housekeeping to do before checking for the video card that the fan should have time to start to spin.
If it still isn't working, try the other memory stick, or remove all memory.
Double check all connections before applying power!
Jul 25, 2008 | Intel Motherboard
Won't boot up
If you hear NO beep code when system starts to boot , it is dead ( one beep then after a few seconds it will beep again before you see windows start up screen )
Jul 20, 2008 | Intel D945GTP Motherboard
Wont post.
Try a few things for me OK? From what you typed, turned on the psu "the toggle switch on the psu", pc seemed to be starting up. I need you to keep the toggle switch on the power supply in the on position. Press and hold the start button on the PC case to shut it down. Give it a few seconds & power up by pressing the power switch on the case. Notice a differance? Next, unplug everything connected to the pc expect the monitor, mouse & keyboard. Try to boot. Still no? Remove the side of the case exposing the board. Turn the psu off by flipping the toggle switch on the psu, wait till the green light on the board goes out. Grab the Mb ( I know it's tight in there) and see if you can move the board in any direction. Not loose? Re-check all data & power connections for a solid connect. Re-check your case to Mb connections. Also check the PSU, there is a red slide switch it should be set to 115v. Post your findings..
map
Jan 28, 2008 | ASUS P5ND2-SLI Deluxe Motherboard
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Intel D945GTP Motherboard Logo
182 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
