Question about Black & Decker String Trimmer Cordless 12" 18V
I have a 12inch cordless black and decker grasshog and the spool of string comes off when the gas is pressed on the grasshog. I have had no issues with the string "not" coming out but the whole spool falls off.
5 Suggested Answers
  • 313 Answers
SOURCE: I CAN NOT FIND THE
see www.dewaltservicenet.com, www.toolpartsdirect.com or www.ereplacementparts.com all info you need
Posted on Jul 26, 2008
  • 16 Answers
SOURCE: I need directions to replace string on black and
Go to home depot. look at the floor model and the replacement spools they sell there. Reverse engineer the stringing process or but a pre-loaded spool.
Otherwise,
1. Squeeze the tabs on the side of the head of the unit to remove the spool cover.
2. remove spool.
3. place end of string in small hole in center ring of spool.
4. wide spool with string in the direction of the arrows printed on the spool. DO NOT OVERLOAD!.
5. snap string into notch on spool and cut string leaving 6" exposed.
6. thread 6" of string through hole in side of unit head, replace spool, and replace cover.
7. go cut grass.
Posted on Jul 07, 2009
  • 64 Answers
SOURCE: Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Posted on Aug 07, 2009
vincob
  • 718 Answers
SOURCE: how to string spool for black and decker corless
Go to smalleng.com they have video on how to do what you need. Check it out awesome website!
Posted on Apr 08, 2010
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
Black and Decker Grasshog auto line feeder just spits line out non-stop. Tried lots of things but nothing seems to work.
I'm gonna take a guess and say you re-spooled the line yourself. If you did you may have put too much line on the spool. The max. is 30', but I've found that that can cause jamming, which forces out more line, if not done perfectly. Reduce the amount of line by about 5 feet and you should be OK.
Apr 10, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
String will not advance on black and decker grass hog electric trimmer
Did you re-string it? If you did it is possible that you crossed the string over itself and it is stuck. Check that and good luck...Lee
Oct 20, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black and Decker Grasshog Malfuntion
Make sure to look at the spool. There should be an arrow showing which way to wind the string...Good luck...Lee
Sep 16, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I need directions to replace string on black and decker cordless 18v grasshog
Otherwise,
2. remove spool.
7. go cut grass.
Jul 07, 2009 | Black & Decker String Trimmer Cordless 12"...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
64 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
EugenesDIYDen
EugenesDIYDen
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
