Question about Fuji FinePix S20 Pro Digital Camera
Fujifilx Finepix S20 Pro - Viewfinder and Screen Problem
My Fujifilm S20 Pro has developed an issue with the viewfinder and the LCD screen. The view finder is completely black and the screen has a large green "glob" in the middle. It will not hold the picture for more than a second. I took it to the camera store and they said that the aperture sensor is bad and the repair will be aprox. $250-$350 or to buy a new one. Please help! Thankyou.
cammedic
  • 667 Answers
SOURCE: viewfinder
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Posted on Jun 09, 2008
keemo68
  • 1263 Answers
SOURCE: fuji s 20 pro
prior to this current problem did the pictures have a hazy contrast to them? if so then yes the apeture is faulty. if the cost of the camera does not exceed the the repairs then you should purchase a new one. this is the best option because i'm sure if you send it straight to fuji it will cost more than 350 bucks guarenteed. however you might save alot by just taking it to a local shop and have them repair it and you most certainly get it back alot quicker as well.........please rate this thanks
Posted on Sep 04, 2008
thaurfen
  • 623 Answers
the store manager is right the sensors are bad,
and you can buy a new camera with $250-$350
good luck
  • 275 Answers
SOURCE: FUJIFILM FINEPIX S5000.No image on viewfinder or LCD.
I think there is a small button on the back of the camera near the bottom that turns the viewfinder off and on I think. It should be in the manual.
It might have gotten bumped while in the bag.
Posted on May 24, 2010
  • 214 Answers
SOURCE: Hi my fujifilm finepix S20
hi It looks like ccd unit or main pcb failing. Mostly the ccd unit is numerous problem on the market. Skype me after 6 pm pcc0814@yahoo.com, I will try to help you. Thanks and best regard!
Posted on May 23, 2011
No view from screen or viewfinder
Hi, have you tried another memory card in case the other one is faulty ,if the original card is ok then you will have to put into a fuji repairer to inspect. If you are still under guarantee the contact fujifilm.
Dec 17, 2015 | Fuji FinePix S5700 Digital Camera
Fuji s 20 pro
Sep 04, 2008 | Fuji FinePix S20 Pro Digital Camera
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
Hi my fujifilm finepix S20 pro has developed a problem where the LCD screen and if you use the viewfinder have become totally un watchable like an old analogue television that is out of tune? Keith
May 23, 2011 | Fuji FinePix S2000hd Digital Camera
May 24, 2010 | Fuji Cameras
Finepix S1000fd just suddenly quit working...
I'm not sure how old this is, but I had this identical problem on my Fujifilm Finepix S1500 and the solution was embarrasingly easy and it may be related to this same problem. If your camera has a viewfinder, see if there's an image there. If so, look to see if you have a EVF/LCD button or something similar on the back of the camera. If so, press it. What had happened with me is that my wife likes using the viewfinder for framing and she presses that button to turn off the rear LCD and on the viewfinder. Maybe the button got pressed accidentally. Press it again and it should switch back. Hopefully this is the solution.
May 26, 2009 | Fuji FinePix S1000FD Digital Camera
FinePix S5700 LCD Screen Problem
you need to send it to fujifilm for repair. i dont think its too expensive at all. this is a common problem with many cameras
Apr 14, 2017 | Fuji FinePix S5700 Digital Camera
My fujifilm s700 takes pictures but the lcd screen is busted.. you can see the pictures and screen through the eye piece.. but thats it. What should i do?
The only thing you can do is take or send the camera to an AUTHORIZED service center for replacement of the LCD screen. If you can live with just using the viewfinder, like in the old days, the LCD being broken should not effect the camera operation. Set the selection to the EVF (electronic view finder) position and this will stop the LCD screen from coming on. If this has helped, please rate it accordingly. Thanks and good luck. (BTW: I LOVE my Fuji S700)
Apr 29, 2009 | Fuji FinePix S7000 Digital Camera
Fuji s 20 pro
CCD module failed, contact fuji, they got product recall for some camera models with faulty CCD
Mar 06, 2008 | Fuji FinePix S20 Pro Digital Camera
LCD screen and Viewfinder not functioning
there is probably a problem with the connection between the sensor and the displays, I would send it back to Fuji for repairs, because it would be almost certain death for your camera for someone who does not have the machinary and clean room to service the camera to try to fix it
Nov 22, 2007 | Fuji FinePix S9500 Zoom Digital Camera
Fuji FinePix S20 Pro Digital Camera Logo
23 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
