the kodak system uses a countdown system that assumes you use a certain amount of ink re sheet regegardless of how much ink you accutualy use, the counter system starts everyt ime you turn the printer on, so the only way to extend the life of the ink is not to turn the printer off netween use, which the domestic useres do not of course do what i did throw the printer away and get a new one not Kodak sh*t
if the ink cartridge is the same ink cartridge since you have pruchased it, it may have run out of ink or the ink cartridge is broken, that is the only two posible reason thats why you always recieve these messages, check can check the ink capacity through the hp utility tools, if the cartridge has run out of ink or it is broken you will need an ink cartridge replacement
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Open the printer and remove the ink. Clean around the ink carriage and
the under the ink with alcohol and a cotton swab. Pay special attention
to areas with copper contacts. Keep
in mind too that some printers will not print, even with full ink, if
the exact type of ink it expected you to have installed is not right. Double
check that the ink is correct against the manual or written
instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the
printer necessarily works.
Is it the new original cartrigde colour or not ? If yes, you should ask a guarantee from the seller.
There is a chip inside the cartridge, sometimes it doesn't compatible for the printer software to read the chip.
The printer will keep asking for the new one if there is no ink in the cartridge.
Dear Black Rose
It is strongly recommended to change your colour cartridge.
Or it can be possible that you did not use your colour cartridge for a long time.
The nozzle of colour cartridge are blocked, if you did not use your colour cartridge for a long time.
Purchase a new cartridge if you can or go for a local refiller to refill (if possible) your colour cartridge.
Thanks
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
