Question about Zenith C27A24T 27" TV
I have a Zenith C27A24T the picture is out of focus.
I have a neighbor kid who took the back off to see if he could fix the video connections. (too many games of PS2 disconnecting to the back have broken the connections at the board.) When he put it back together the picture lost its focus. Any suggestions on how to get it back, or if it's even worth sending outfor repair?
  • 4,234 Answers
If there is no other problem, he probably touched the focus adjustment in the back of the set. Open up the back and locate the flyback transformer (part with large red wire coming out the top). There will be 2 adjustment controls on it. One should be labeled screen, the other focus. Adjust the focus until crisp.
Dan
Posted on Sep 04, 2008
Zenith C27A24T 27" TV does
Greetings - You need to have you DVD player hooked up to the video inputs - See below. Don't mind the mouse scratch out lines. The Device on the right represents your DVD player.
You then have to choose video as your source on the TV (not channel 3 or 4) using your remote - see below.
You should be good to go.
Enjoy your movies,
Mikeywaf
May 22, 2011 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV -
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board (also on circuit board that is fixed to CRT TUBE ) at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears or rolls ( in your case )...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer
Apr 21, 2011 | Zenith C27A24T 27" TV
Colors are blurred
There is a focus control on all CRT sets. It would be on the back of the set. It might be accessible or it might be inside which would involve removing the cover off the set. This is not recommended as there is very high voltage present in there. If it is accessible from the back without removing the cover there will likely be two little plastic knobs. One marked "F" for focus and the other one marked "S" for screen.........don't rotate the screen control, adjust the focus until your picture becomes clearer. If this doesn't help a whole lot then your picture tube might be shot and that means time for a new TV.
May 24, 2010 | Zenith C27A24T 27" TV
I do not find a vedio/audio(red, yellow, white)ports to connect to my DVD player. What is the alternative way to connect to my DVD player using this TV? Thanks
There are 5 RCA connectors on the back of this TV, (according to the manual). The lower three from left to right are Video in, Audio Left in, Audio Right in. There are also two RCA connectors above these that are the L/R audio outputs. Also, there is an S-Video input which I would recommend using instead of the RCA Video in. You'll still need to use the RCA inputs, but the S-Video will give you the best video connection into this monitor.
Oct 31, 2009 | Zenith C27A24T 27" TV
Just got a dvd player, how do i get to play dvd mode?
There are connections on the back of your TV for Audio and Video inputs. You connect the corresponding connections to your DVD player. You then use the TV/VCR SOURCE button on your remote to change to that input. In case you don't have your manual the following web address will take you to a place that will let you download the manual.
http://www.retrevo.com/support/Zenith-C27A24T-TVs-manual/id/277ag102/t/2/
Sep 10, 2009 | Zenith C27A24T 27" TV
Dark picture after storm.
Dark picture? hmm.
meaning there is no brightness variation, assuming this is the fault I think U might be having low screen voltage. Check for high value ( around 2W) resistor, preferably from 100K to 680K on the "C" board or neck board. Post back
Rifaa
Nov 03, 2008 | Zenith C27A24T 27" TV
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Aug 28, 2008 | Zenith C27A24T 27" TV
An old zenith tv
press -------- |tvvcr | |source| -------- its by the timer button on the bottom of the remote
Aug 11, 2007 | Zenith C27A24T 27" TV
Problem with the color on my Zenith
picture tube need a picture tube reguvinator $1300
Apr 29, 2007 | Zenith C27A24T 27" TV
Zenith C27A24T 27" TV Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
