Question about Konica Minolta DiMAGE A2 Digital Camera
What types of metering methods are available?
    Master:
  • 425 Answers
Multi-segment metering (300 segments), Center-weighted metering and Spot metering are selectable. The position of the spot metering area can be specified at the center of the live image or linked to the Flex Focus Point.
Posted on Sep 15, 2005
Ip check pananum please sollunga
There are two methods available to check your IP address.
Method 1:
Go to start.
Select Run. The dialog box will gets displayed.
Type cmd. Command prompt will gets displayed.
Then type ipconfig or ipconfig/all.
It will displays your IP address.
Method 2:
You can find your network IP address using the site Ip-Details.com
Apr 15, 2013 | Computers & Internet
Tip
Principles of Truck Cleaning
There are different methods available to clean a truck. The method to be used depends on a range of factors including but not limited to:
1 Availability of cleandown equipment and infrastructure
2 Commodity to be loaded Contaminant type in the truck
3 Prior loads Transport company procedures
4 Time available for cleaning
For more information visit our sites
http://mammothtruckwash.com/
on Aug 24, 2016 | Miscellaneous
I have problem in windows word. my system says that you have aproblem in comand promt
Try the following:
Method 1: Change File Type Association Directly from the File Properties
1.Right click on a file with the type or extension that want to change its associated application program.
2.Select Properties on right click context menu.
3.In the General tab, click on Change button.
4.An Open With window will appear. Choose a program to open the kind of file from the list of programs available. By default, Recommended Programs is automatically expanded. However, there is more detected programs in the section of Other Programs, which can be expanded to select by clicking on Down Arrow at the end of the separator line.
If the program that want to used as the default program does not found, click Browse to select an executable file manually.
5.Click OK button.
Method 2: Change File Type Association Directly On The Fly
Note that this method works if only several programs have been used to open and run a kind of file type extension previously.
Feb 10, 2011 | Compaq Computers & Internet
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
  1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
Screen Method Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
  1. Before starting headlamp adjustment:
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    Mark a horizontal reference line on the vertical wall or screen.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
    Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
    On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
VOR type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
Pressure builds to about 220 then cuff pressure drops off
These cuff-type BP meters are very unreliable; I have bought 4 (one standard type) so far and the one that is still working predictably measures about 10% low. I took it to my GP on an office visit and we compared the systolic & diastolic results and although three different methods/instruments (manual, upper arm portable digital and a stand mounted 'professional') also tracked poorly, mine (Samsung) measured lower than all other methods.
I suspect the sensor that should be doing the measuring is faulty.
May 17, 2009 | Life Science Life Source Blood Pressure...
My phone is nokia 6300 i do'nt no solution enter restriction code
Enter Restriction code message is displayed on Nokia handsets, when you try to use a sim card from another network to what the phone is currently locked to...
To unlock this handset there are 2 options:-
1, You can get the correct unlock code which you just type in from the phones original Network, they will usually charge for this... FREE codes available on the net will not work for this handset and you only have 3 attempts to enter the correct one...
2, You can have it unlocked at most decent phone shops, using specialist equipment, this method is only available if you have a firmware version below 7 (I think cant quite remember) if its above that then its the new security type SL3 which is currently not unlockable using any available equipment or software... The only method is by option 1 above...
May 13, 2009 | Nokia 6300 Cellular Phone
How do you open a Rex II light meter --probably 1970 or 80s. It's an old analogue meter. Runs with 2 coin batteries. I want to look inside the guts and adjust the galvanometer.
These were very cheap lightmeters when sold new and as such were not designed to be serviced.
You aroused my curiosity so I've just tried opening a scrap one and it appears to be glued together, I tried my usual method of cracking along the join line but as the plastic appears to be a type of bakelite the casing cracked instead.
If you want to open this meter I'd recommend using a razor saw around the join line to separate the casing halves. Afterwards I'd recommend using epoxy resin to rejoin the two halve.
Apr 10, 2009 | Cameras
Type of flash control
DiMAGE E500 employs Preflash-TTL metering method.
Sep 19, 2005 | Konica Minolta DiMAGE E500 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
comment
comment
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
