Question about Hitachi 43UWX10B 43" Rear Projection Television
HITACHI 43UWX10B SERVICE MANUAL
HI,
You mentioned you downloaded a service manual for this model. I just experienced a problem with convergence we have blue double words and would like to get a service manual if you got one from rich.
Thanks,
Michael Farnell
m.farnell@yahoo.com
  • 927 Answers
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Posted on Sep 06, 2008
How do I locate resistor values?
Click HERE to download service manual copy for free. Download all 12 files and unzip with winrar to get pdf file.
Hope this will help you to find out required resistors value.
Oct 28, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Need service manuel free download site or codes for circuit board to reset to manufacture settings if possible on convergence problem
You can get a free manual if you buy a kit from www.TvRepairKits.com . They will typicaly email one to you if you just ask.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B Service Manual
Good Day;
Aug 09, 2008 | Hitachi 43UWX10B 43" Rear Projection...
43UWX10B
i can not give you a schematic. I can look at the schematic and help you with your problems. First I'm goin to need to know your symptoms and/or location numbers of the parts in question.
I am an autherized service tech for Hitachi.
Jul 02, 2008 | Televison & Video
43UWX10B
It's not coming on probably because the safety sees a short and is sparing you smoke damage. Double check to make sure any solder didn't cross or drop to another set of solder joints on the bottom. You might be able to get a service manual from here that could tell you more about the lights -> https://www.manualsparadise.com/ShowProductsForModel.do?model=M22931911
Apr 26, 2008 | Hitachi 43UWX10B 43" Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence problem
Well you need to get into your tv's service menu and service convergence mode. It's different for every tv. It means entering a code on the remote that opens up a secret menu for changing tv settings. Go to servicemanual.net and buy the service manual for your set, you'll be glad you did.
Mar 23, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Convergence resistors burned up
Hi, which ones do you need the values for? e-mail me and I`ll give you them, you`d probably bebetter off to order the kits with the new stk`s and all resistors included, you can get those from your distributor if they sell Hitachi, if not get them at Tritronics, let me know which ones you need, BMW Rider
Jan 20, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 50UX22B Convergence Problem
there is a company called pts that will rebuild the board for u just send it in the will repair it and send it back , alwways use your wristground strap.
Nov 21, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Set is still slightly out of convergence after repair
Download manual & get info at www.HitachiServiceUSA.com....
Oct 29, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
302 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
