Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
Where to located Boards
I'm having problems locating replacement Boards.
You posted to replace both the Y-Main and the Y-scan boards at the same time for repairing the AKAI PDP 4294.
Is is just fixing the boards with new parts or do you actually purchase a whole new board.
Please help. I am new but ready to learn!
Thanks
Ryo
Ryo,
I would suggest you send your boards or the complete chassis to a company called PTS Electronics.
They will do a complete test of the boards and replace the defective components.
Posted on Sep 11, 2008
Hello! I have a Toshiba 42HL67US. I am looking to replace the T-Con board, but Don't see the board when the rear case is removed. I need a diagram showing the locations of the boards. Thanks
Follow the ribbon cable from the main board to the T-Con board. Most likely at the bottom of the TV and could be behind a metal bracket.
Oct 20, 2017 | Toshiba Televison & Video
Samsung PN50C550G1FXZA clicking on and off, already replaced power supply board, main board, and main logic control board, yet the problem persists, what else could it be?
Those blinks are short circuit indication. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 05, 2017 | Samsung Touch of Color PN50C550G1FXZA 50...
Where is zsus board located
Samsung 50 Plasma Parts ' eBay
www.ebay.com/bhp/samsung-50-plasma-parts
eBayFind great deals on eBay for Samsung 50 Plasma Parts in TV Boards, Parts and ...Samsung 50" PN50C430 LJ92-01728A Plasma Y-Main YSUS Board Unit Motherboard.... Part Number: LJ92-01705C (Partial PBA number (705C) can be found on a ...Samsung HP-R5072 50" Plasma HDTV Main Board BN41-00632A ...
Samsung Buffer Board Test and repair Part 1 - YouTube
? 11:20
https://www.youtube.com/watch?v=5hVi5gd0aec
Oct 5, 2010 - Uploaded by z28r2fast4u
I checked two buffer boards and found 11 out of the 12 ic's bad.... my samsung, I post the video here, do you know how to test YMAIN and ZSUS ? .... Samsung PN50C450 with a bad Plasma Panel Shows how to replace the ...
Jan 18, 2016 | Samsung HP-R5072 50 in. Plasma HDTV
Vizio GV47L flatscreen TV has no picture although it will power on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 05, 2014 | Televison & Video
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Tv doesn't power on properly and sometimes not at all
Hello Sir, hi, your TV is in serious order, this could be traced from a failure of the power supply board to the mainboard. This diagnostics should be done by a qualified service personnel and should not be performed by a novice. The process is to locate the problem board, first replace the power supply board, then test, if the board respond then good, but if not, then the problem is on the system/main board, we then replace the main board which controls the sound, LCD, controls and the likes. at this point the TV most likely be powering on. But replacing the two boards are costly, so I suggest you take it to your dealer for proper advice on your TV. if its under warranty, much better. they will replace the entire tv.
Nov 19, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Where to replace burnt out PCB.
ok if you check the board-boards and replace all
the caps that have vented (expanded) with new ones. you may be in good shape then!
Jun 19, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Eror code 12-22 then 53-54 in sony pfm-500a3we
Dear sir,
Code 53-54 means 2 fans on the behind of your Sony are not working.
This could effect the code 12/22.
Hint :
First fix the 2 fans.
If they're working , see if the code 12/22 has gone too.
If all the fans are working .... all 5x codes are gone !!!
If the code 12/22 is still present ..... the Sony turns on and off again and again.
In this case it's NOT the power supply unit !!!!
But you need to replace the X-SUS & Y-SUS print-boards inside your plasmascreen.
Located on te main printboard on the left and th eright side.
Replacements will cost arround the € 150,00/$ 100,00 for both boards.
Dis-connect the cables from the boards and un-screw the boards.
Replace the boards and re-connect the cablas and screws.
Problem for code 12/22 has being solved !!!!
Best regards , EuroNet 2000 The Netherlands
info@euronet-2000.nl
Feb 24, 2009 | Sony PFM-500A2W 42 in. Television
Followup on power connectors
Hi chweb1230, to answer you're question. Yes, I would suggest getting a power supply that would comply with the ATX main 24-pin power connector. The term backwards compatible references to boards that require less voltage, Ex; (A 20-pin main power board). If you intend to run serial ATA SATA drives & a PCI-E graphic card. The newer power supply will handle future upgrades. Suggest a 500 to 550W PSU should handle just about anything you add to the board.
chweb1230, when you make a post & are making reference from another post. Please copy & past that link into this post. If you are using a new user ID I can not look back & find what you are refering too.
How to vote you're expert & also how to repost more questions for same problem or to answer expert's questions for a posted question.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Add another question to the current post....
Under the solution given by the expert, choose a color, one of the following: Vote.
"FixYa!" -The solution provides great advice on how to solve the problem (marked in blue).
"Helpful" -The solution provides helpful information that helps solve the problem (marked in green).
"Thanks for Trying" -The solution provides some help but does not solve the problem (marked in yellow).
If you need more help or have more question please do not hesitate to post further.
Enjoy!
Mike
May 18, 2008 | Intel DG31PR Motherboard
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
123 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
