Question about Vivitar ViviCam 3632 Digital Camera
Did I lose all of my pics
I turned the camera on while the camera was hooked up to the computer and now all of my pics are gone. Did I lose them or can i get them back?
Camera wont transfer my pic so i can see then
Posted on Dec 10, 2010
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Sep 04, 2008
I can't get my pic from camera's memory card to upload. Neither from camera hooked to PC, nor memory card in PC's memory card slot. #2) I can't view my pic on the camera either. The
If you hook up your camera using the usb cable make sure the camera is on. Next go to my computer and click on the drive that is new and open,. then you can access your pictures.
Jan 11, 2013 | GE X500 Digital Camera
As soon as i start the computer I get the message HP Image Zone- Error the program has encountered an unexpected erroe.: Object refrence not set to an instance of an object.
YOUR CAMERA MAY NOT BE CONNECTED? IF IT IS CONNECTED, THAN CLICK ON START, TYPE IN HP IMAGE ZONE, CLICK ON THAT PROGRAM GO TO PROPERTIES AND UPDATE YOUR SOFTWARE.
YOU MAY HAVE TO UN-INSTALL YOUR SOFTWARE FOR HP IMAGE ZONE...ONLY IF YOU HAVE THE DISK...THEN RE-INTSTALL AGAIN? WHEN UN-INSTALLING YOU WILL NEED TO UN-INSTALL ALL FILES SO SAVE YOUR PIC'S ELSEWHERE ON YOUR COMPUTER BEFORE UN-INSTALLING!
IF SO...MAKE SURE YOU SAVE YOUR PIC'S IN YOUR DOCUMENTS OR ON YOUR DESKTOP IN A ZIP FILE, SO NOT TOO LOSE THEM.
PLEASE MAKE SURE YOUR CAMERA IS NOT HOOKED UP TO YOU COMPUTER WHILE INSTALLING SOFTWARE FOR YOU HP IMAGE ZONE!
SOFTWARE HAS TO BE INSTALLED FIRST!
THEN SHUT DOWN YOUR COMPUTER, HOOK YOUR CAMERA UP TO YOUR COMPUTER, TURN COMPUTER BACK ON...IF THE COMPUTER DOESN'T RECOGNIZE OR DETECT THE HARDWARE FOR THE CAMERA, THEN YOU'LL HAVE TO GO INTO YOUR COMPUTER AT THE START BUTTON AND GO TO INSTALL HARDWARE!
IF YOU HAVE THE DISK, YOU CAN ALSO TRY JUST PUTTING IT IN YOUR HARD-DRIVE AND IT WILL GIVE YOU OPTIONS OF UPDATING ETC,.
HOPE THIS HELPS!
MARTIE
Aug 24, 2011 | Compaq Presario 5000 PC Desktop
I have GE C1130 and it has a tendency of losing pictures . When you go on the viewing part it shows empty. Also shows empty when you hook it to a computer. I haven't deleted anything. Last time the pics...
This is a formatting problem (in other words, it's likely you did not format the card in your camera when you first got it). First thing to do is back up all photos from the card onto your computer. Afterwards, format the card IN THE CAMERA using the camera's format feature. This will correct the problem from reoccurring in the future, but will also erase the card! So again, only do this after backing up your photos.
Oct 07, 2010 | GE E1030 Digital Camera
WHEN I HOOK MY CAMERA TO MY COMPUTER AND TURN THE POWER BOTTON ON TO THE CAMERA MY COMPUTER "SHUTS DOWN AND WILL NOT RESTART TILL I TURN THE CAMERA OFF. PLEASE TELL ME WHAT TO DO PLEASE MAKE IT SIMPLE...
First of all, stop hooking the camera to the computer to download pics. That's not the best way and obviously, your computer doesn't like it. Get a separate card reader and use it instead of your camera. This one is only $13 at Walmart. 46e433f.jpg
Aug 13, 2010 | Canon PowerShot A550 Digital Camera
The usb dosent work!!!!!!!!!!! plz help
does ur camera have a sound card and does your computer have a card reader, if so you can download your pics right onto the computer, if not you can purchase a card reader that hooks to your computer. if your usb cable doesnt work maybe try a different one or a different computer maybe the usb port has gone bad. on the computer
Nov 29, 2009 | Vivitar ViviCam 5299 Digital Camera
File contains no image data
If you format, you will lose everything...format means erase and optimize. Take your card to a store like Walmart that has a Kodak picture maker machine. It will usually read all the pics on a card and you can make a cd of them on the machine.
Nov 11, 2009 | Nikon COOLPIX L4 Digital Camera
My kodak easyshare c913 turns of when hooked up to usb
Try opening the Kodak software first, then turn the camera on. I've found that you need the Kodak program to transfer the pictures from the camera. I personally do not like this, my old camera (also Kodak) would act like a plane old flash card/removeable device, this new one doesn't.
Anyhow, I find it super easy to just take the SD card out and pop it into the media slot in my printer. Then just open explorer and it's there just like any other hard drive or CD/DVD drive and transfer them to where ever you like.
If your printer or computer doesn't have a slot for SD cards you can get one that plugs into a USB port, pretty cheaply at any store that sells computer products.
Aug 08, 2009 | Kodak EasyShare C913 Digital Camera
Camera wont turn on after trying to download pics to computer/can't find pics on computer now
You probably had a bad USB connection that supllied to much voltage (or had a bad ground or reverse polarity) to the camera and shorted out the circuit board. Disconnect all cables. Hook up to a charger and try again. If this does not work, the camera is fried, sorry.
May 07, 2009 | Kodak EasyShare V1003 Digital Camera
Downloading pics from camera to mac
We had trouble uploading to our mac, especially with videos.  A camera store guy suggested using a card reader instead of uploading through the camera -- it's much faster.  Hope this helps.
Nov 20, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Memory card formatting
Unfortunately, there is no way to format your card without losing any saved pictures. Sometimes, if you insert your card into other cameras or printing kiosks at walgreens or target, it will work. it's a long shot though. Chances are, you may have to lose your saved pictures :(
Mar 02, 2008 | Fuji FinePix 2650 Digital Camera
Vivitar ViviCam 3632 Digital Camera Logo
44 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
