Question about Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve....
Removing an old moen bathroom faucet
I have a 9 yr old moen faucet that inslled from under the counter but held on by c clips around threads on top how do I get the clips off there is no space to prey them open thanks
I have a moen monticello bathroom faucet that is about 12 years old. I cannot figure out how to get it apart???????
Help me, help me!!!!!!!!!!!!!!!
Posted on Feb 20, 2010
The solution to this problem was to literally saw the handles off. There was nothing on the undermount to loosen like sanray suggested. Could not get the clips off no matter what. Could not even see them. This faucet sucks. Replacing it with a Delta which I hope never gives me this much trouble!!
Posted on Jan 16, 2010
    Problem Solver:
  • 14 Answers
The nuts located on the underside of counter need to be loosened in order to releive the pressure off of the C clips and then you will be able to pry them off.
sanray
Posted on Dec 29, 2008
  • Ray Coon Jan 10, 2009
    What exactly are you trying to do, remove the faucet or repair it.
    I assume we are talking about either a mini widespread Moen lavatory faucet or a standard moen widespread faucet.
    President:
  • 1,263 Answers
There is a tool for those clips you can go to a hardware store and purchase the tool for a modest price. please rate this thanks
Posted on Sep 05, 2008
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
My waltec bathroom sink was leaking now that i messed with it ,its running by itself how do i fix this problem
It would help to know where is was leaking and what you "messed with"?
But in general, the idea is to replace the washers.
To do that, first turn off the water under the sink.
Then you first remove the handle on the leaking side.
There is often a small metal or plastic cover over a phillips screw.
Then remove the metal cap around the handle stem by unthreading or lifting up.
Then you can remove the valve by turning it as if to make the water go on.
It will have a washer on the bottom, held on with a screw.
Remove the screw, get a new washer, and then replace.
http://www.moen.com/shared/pdf/instruction_sheets/ins1923a.pdf
Dec 20, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Disconnect/reconnect drain part of MOEN (Adler) bathroom faucet CAL84502. I'm changing the entire basin and reinstalling the MOEN faucet system but can't find my original installation instructions.
Should be 3 wing pipe nuts. One at basin base, and one on each end of you elbow. They should all turn counter-clockwise to remove. The one on the basin base likely and commonly has pipe thread tape on it.
Aug 08, 2010 | Moen Home
"Mintcraft" faucet any good?
Hi, If you asked me, I bought from amazon/ebay depending on reviews... (that way you cant buy something not good). so.. take look Were doing more than just throwing away the key . I hope this helped you. Cheers
Apr 26, 2010 | Mintcraft L5860-03-07 ATLANTIS POLISHED...
Trying to put new cartridge in my moen bathroom faucet and i don't know how to do it. It is a teardrop one handle faucet. Please help a single woman not have to call a plumber!!!
shut water off under faucet,open it to prove wtr is off. pry off cap , slide edge of putty knife,butter knife.etc should see a phillip's screw.remove,pull handle off, pull chrome sleeve off, now. toward's top you should see a little tab sticking out, it is part of a horse shoe shaped clip,pull with needle nose plier's,or similar.pay attention how it come's apart ,your new cartridge come's w/detailed instruction's,calmly refer to 'em, you may need or may not need a moen cartridge puller,(use a good grip,steady pull,)
Apr 25, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Moen single stem bathroom basin tap (25 years old). Trying to remove cartridge to grease it or replace it. Have removed handle and retaining clip. Pulled hard but can't shift it. Don't want to break...
You are on the right track. You have to use some force when pulling the stem from the faucet. Your replacement cartridge should have a little black or whit cap. that is inserted on top of the cartridge and by turning the cap will help loosen the whole cartridge
Feb 21, 2010 | Moen & One Handle Tub & Shower Faucet
Faucet handles fell off
there are supposed to be screws in the handle thru to the stem on the faucet that hold them on
Apr 21, 2009 | Dishwashers
Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Nov 27, 2008 | Plumbing
Pioneer 2 Handle Satin Nickel 6" Rain Head Shower Faucet+Valve.... Logo
2,076 people viewed this question
Top Pioneer Plumbing Experts
Donni Steen
Tom Chichester
Are you a Pioneer Plumbing Expert? Answer questions, earn points and help others
