Computers & Internet Logo
Posted on Aug 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it possible that I can install 3 different sound cards on 1 PC?
Anonymous
Level 3:
  • Master 570 Answers
  • Posted on Aug 10, 2011
Anonymous
Master
Level 3:
Answers
570
Questions
0
Helped
152256
Points
1304
Yes, You can install 3 different sound cards on one PC, but you cannot use all 3 at the same time.You can use any one of them at a time. You will have to set one default sound device to listen music. If you want to use all of them then one thing you can do is, you can connect 2 or 3 different speaker sets for each sound device.
Hope the above information will be helpful to you. Thanks for contacting Fixya. Have a good day.
2helpful
2answers
After system restore sound card wont work
Removing the sound drivers In Windows XP, click Start , and right-click My Computer .In indows 95, 98, and Me, right-click the My Computer icon on the desktop.Click Properties from the list that appears.In Windows XP, click the Hardware tab, then the Device Manager button.In indows 95, 98, and Me, click the Device Manager In Windows XP, click Uninstall (the small picture of a computer overlaid by an X In Windows 95, 98, and Me, click Remove .Click OK when a warning window appears.Continue to remove sound devices that relate to the audio card brand (not Legacy) until all have been removed. If the device is a combination sound-modem card, remove devices related to the brand name listed under Modem as well.Close all programs and turn off the PC.Back to top Step 2: Disabling on-board sound Skip this step if the PC does not have onboard sound. If PC does have onboard sound, do the following to disable it Turn on the PC and press the F1 key repeatedly at the first logo screen. "Entering Setup" should appear on the screen.In the Setup screen, press the LEFT and RIGHT ARROW keys to highlight Advanced. Press the DOWN ARROW key until Onboard Audio , Onboard Audio Options , or I/O Device Configuration is highlighted, press ENTER .If another menu appears, press the DOWN ARROW key until Onboard Audio codecs or Audio Codec is highlighted, press ENTER .Press the DOWN ARROW key until Disabled is highlighted, press ENTER .Figure 2: Example of one possible Onboard Audio BIOS setting Press F10 , then the Y key, to save the settings and exit.Turn off the power and continue to Step 3.The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer.This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a noncarpeted floor, use a static dissipative work surface such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.Unplug the power cable and with the power cable removed press the Power button on the front of the PC.Remove the screws on the rear of the PC.Figure 3: Side Panel screws (your PC may be different Slide the side panel off from the rear of the PC.Figure 4: Side Panel removal (your PC may be different Step 4: Removing the sound card Use this section to remove the sound card. If the PC was using onboard sound and you do not have to remove it, skip to Step 5 .Locate the sound card inside computer case. Use the speaker connections on the back as a reference. Disconnect any cables that are plugged into the back and sides of the sound card. Carefully note where each cable was installed.Remove the one screw that holds the sound card to the chassis. If a metal plate covers up the screw, then remove this plate first.Figure 5: Screw that attaches card to case Grasp the sound card by its edges and slide it out of its slot.Figure 6: Card removal If the sound card is a combination sound-modem card, disconnect all cables from the modem and remove it in the same way that the sound card was removed.5: Installing the sound card Insert the new sound card into an open compatible slot. If you have a sound-modem ombination card, insert the new modem card into an open slot as well. Attach the card or cards with one retaining screw. Replace the metal plate if it was used.Connect all the cables back to their original positions : Replacing the cover Replace a side panel by matching the side panel tabs with the tab openings in the case. Figure 7: Side Panel tabs (your PC may be different Insert the side panel and slide it forward.Figure 8: Side Panel insertion (your PC may be different Fasten the screws to secure the side panel.Figure 9: Side Panel screws (your PC may be different Installing the software and drivers for the new card s Connect all cables and turn on the PC Use the software installation instructions that came with the new sound card to install the software. Normally a CD is inserted after Windows finds the new hardware and displays a message.If the new sound card is a replacement for an original card that came with the PC, Windows should find and install the software automatically. If needed, you can install/reinstall the sound software using the HP Application Recovery software that came with your HP or Compaq PC.Original and updated drivers may also exist on the HP Website. After installing the original driver, go to Software and Driver Downloads site and enter your PC model number to find software and driver downloads.f a window appears stating that it needs help finding particular files, place the driver disc from the soundcard manufacturer into a disc drive. If this does not help, browse to the following pathnames, one at a time, until the file is found: C:indows\inf
C:\Windows\options\cabs
C:\Windows\system
C:\Windows\system32
If the files under these pathnames do not appear, open the C:\ from My Computer . Click Tools , Folder Options , and click the View tab. Remove the checkmarks from Hide protected operating system files , and select Show hidden files and folders . Click OK .Restart the PC and test for sound.
No songs are playing
1.try playing them in different players.
2.make sure that the audio settings in your control panel are right and not in MUTE.
3.last case re-install the sound card driver ! this will solve your prb!!!
if not then your speaker must have failed !!!
1helpful
No sound device
No Sound Device notification suggests that your Sound Card Driver had corrupted due to some sort of file deletion process or change in your registry. (Which could be due to a virus attack).
1 - First and foremost, if your PC is feeling a bit sluggish, download and install a free anti-virus like Avira, from this link:
http://www.avira.com/en/avira-free-antivirus
2 - Check your system for possible viral infection.
3 - Clear or delete any suspicious files.
Now if there is no viral infection and Avira declares your PC free from any mal-ware then go on
1 - Remove the previous installation of your Sound Card Driver using Revo Uninstaller Portable, it can be downloaded from the following link.
http://www.revouninstaller.com/download/revouninstaller.zip
2 - It would ensure that no previous installations of that driver are intact.
3 - Reinstall the sound card driver.
Hopefully it would help you solve your problem.
Thanks for using FixYa.
1helpful
Reformatted Windows XP does not recognize D-Link wireless adapter
I ran recently across the same problem and solved it by changing the PCI slot where the card was installed... it makes little sense to humans, but apparently make a world of difference to the PC hardware ;)
Assuming you had installed unsuccessfully both Card and Driver you have them (like I did) both on your PC. In such ase, the solution for me was as follows: 1) Turn Off PC 2) Remove the card from the current PCI slot 3) Turn PC back On and remove driver 4) Turn Off PC, remove power cord and wait a minute or two 5) Do not install card yet 6) Turn PC back On and install the driver 7) Turn Off PC remove power cord 8) Install the Wireless card in a different PCI slot THIS IS VERY IMPORTANT!!! Can't be the same slot as where it was installed before!!! Note: If you have none available swap PCI slots or remove a PCI card to free up a different slot for the wireless card... remove a card you need the least and in its place install the Dlink Card. You may want to hold off on installing in a second step the card you have just removed, to be on the "safest" side.
9) Once the card is installed, Power up your PC 10) Once windows will be back up and running the hardware wizard should kick in and tell you that new hardware was found. 11) Follow the on-screen instructions 12) click "Continue Anyway" when XP will warn you that the driver hasn't been signed 13) Installation should be completed after you click Finish at the end of the New Hardware Wizard process 14) Simply go to your wireless networks and make sure all works in order
(I know that this process may sound a bit "anal" in some steps, but I was no longer willing to deal with any possibility of problems of any kind as I was ready to rip that wireless card to shreds!)
I hope this will help those who struggled with reviving an old PC to give to a friend!
My desktop cannot detect the card which i have inserted in a pci slot which is fully functional.When i tried downloading and installing the driver, an error message pops up saying wlanapi.dll file not...
I posted how I solved the problem which was sparked by the suggestion posted by user "thisemily" on this post. I am repeating it here below to spare you the extra click, although I hope you have solved your issues by now! ;)
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
Audio card
audio card enables your computer to play music with headphone. todays computer have inbuilt audio card in them.however if your computer don't have in built one ,or u want to upgrade your sound playing capabilities of your system, u can install it.
There are basically 3 types of sound card in your system
1.audio (sound)card in *********** board
2.internal
3.external sound cards.
mother board sound card can't be removed.
However u can install internal and external audio cards and dissable motherboard sound.External card connect via USB.
Umsuccessful instalation of tv capture card, [email protected]
first the sound driver is not installed in ur pc
no picture would be shown unless u have not installed ur sound card
Remove the card & clean it & placed it & proerly installed the graphic card driver it might solve ur all 3 problem
Installation Error
there could be either one of the 3 parts which is giving u this error
1) instalation cd ...(try installing from a different cd )
2) cd/dvd drive ( try with a different drive )
3) faulty memory card
mostly this issue is being created by faulty memory card if possible try that first
2answers
Sound on my Acer laptop, vista windows
installing a program through windows.com should reinstall your sound
Grand Canyon Tech
Grand Canyon Tech
