Question about LG WM-2277HW Front Load Washer
Lg washer pressure switch error code
Can i get past it without changing it out?
  • alwayspg1 Sep 04, 2008
    thanks much when this one finally bites the dust i will never own a front loader again!
  • 725 Answers
If you pressure switch only has 3 contacts you can jump it but most newer ones have 5 or 8 contacts and you can't really do it.. just need to replace it.
Posted on Sep 04, 2008
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Whirlpool washer F3 E1
F3E1 Error - Pressure switch/ sensor fault.
  • Your washer cannot detect the water level. Check the pressure sensing hose for kinks or blockage or the pressure sensor itself.
  • I won't leave you without a clue. Follow the link below and it will explain more than I can write here.
  • http://applianceassistant.com/Washer-Repair/Duet/Duet-Washer-Error-Codes
  • Jan 02, 2017 | Whirlpool Washing Machines
    Hi I have a lg fuzzy logic wf-1022tp top loader. When I switch it on it says PE pings whole time please HELP
    PRESSURE SENSOR ERROR // Water level pressure switch error
    The manufacturer has assigned this error or fault code to indicate that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
    Jul 04, 2016 | LG Washing Machines
    Error code 13. Turned water on to machine and it leaked.
    Try this link
    it says the following:
    E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
    Shop Parts Outer wash tub, Air hose, Water-level pressure switch
    Frigidaire Front Load Washer Error Codes Sears PartsDirect
    Jun 09, 2015 | Frigidaire Washing Machines
    PE error code for my lg washing machine
    The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
    Mar 15, 2015 | LG Washing Machines
    "PE errors lg washer wm2032hw" I replaced the
    Check the condition of the tube as any small crack or hole will render the pressure switch useless.
    If in doubt replace the tube.
    Sep 03, 2013 | LG WM-2032H Front Load Washer
    Error message - PE.... on lg intello washer. my washer is full of clothes and water.it won`t get to the cycle for rinsing .I press on auto-off , then start-pause . the light for water-level does not go on...
    Is there a lot of water inside like more than normal? That is a pressure sensor error. Check pressure hose inside the washer. It is a small hose about 5/16" diameter connected to the tub and pressure switch. If there's a hole in it the air scape and the pressure switch will not turn off the water. The control board detects the problem and stop will show error code.
    Nov 21, 2017 | Washing Machines
    How to reset eprom for PE error
    Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
    Apr 08, 2010 | LG WFT1071TP Top Load Washer
    Lg front loader washer error code -PE
    Procedure for changing it is :
    • Power off the machine remove backcover and top cover.
    • The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached.
    • It generallysits just under the top cover.
    Hope this helps.
    Thanks for using Fixya.
    Shane
    Jan 20, 2010 | LG Washing Machines
    Machine overfilling
    You need to check the pressure switch and tube wich you can access from the top of the machine with the top removed. the tube is a rubber pipe which may have fallen of the switch or pressure chamber connection. cheers
    Mar 25, 2009 | LG WM1812C Front Load Washer
    LG WM-2277HW Front Load Washer Logo
    467 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
