Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Posted on Sep 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Noisey dryer dryer making noise when spinning
  • 1 more comment
  • Anonymous Nov 13, 2008
    I have the same problem. can this be fixed by a homeowner?
  • Anonymous Jan 09, 2009
    I have the same problem. However, the squealing is only intermitted but there is more so a knocking and roaring type noise I am hearing. Can some one tell me what the fix for this is?
  • tofteland Mar 01, 2009
    my kenmore dry makes noise while spinning, like somthing is loose.
Anonymous
Level 3:
  • Master 750 Answers
  • Posted on Sep 13, 2008
Anonymous
Master
Level 3:
Answers
750
Questions
0
Helped
490848
Points
2063
Peace bumbabob,
Huuum t your service!
1-it may be the belt squealing or high pitched noises telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on! I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU
3 Related Answers
Anonymous
  • 187 Answers
  • Posted on May 22, 2009
SOURCE: Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
wildwest1959
  • 25 Answers
  • Posted on Jun 25, 2009
SOURCE: very noisey on spin cycle
Almost certainly the main drum bearings have failed.
Anonymous
  • 15935 Answers
  • Posted on Sep 19, 2010
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Frigidaire FDE546RES dryer - is very noisey as the drum spins. Can you give any insight?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 17, 2011 • Dryers
2answers
Dryer making noise when turned on
you have to specify what make your dryer is to be able to answer question
Feb 06, 2010 • Dryers
Dryer makes loud sound while running sounds like a bearing
a lot fo things cause noisey dryer . ( look for wire clothing stays in drum/ pins in the felts back and front. or dad may have left a sheet rock screw in his pocket . or a key / these things we take out of dryers every day . look hard . i think you will find some thing .. slow sounding noises are related to the drum . fast and hi pitched noise repate to motor and drive componet's .. mm
1helpful
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
1helpful
  • Hi,
  • Try these:
  1. Balance the load
1helpful
Whirlpool dryer making noise and shaking! The bin
The dryer has "rollers" underneath the dryer drum that support and allow the drum to roll smoothly when drying.
I believe one or both of your rollers are worn out. In either case, make sure you replace them all or you will be doing this again in the near future when the other one decides to fail.
Below is a diagram of the rollers ( #44 ) that need to be checked and replaced.
Let me know.'
Regards,
Very noisey gas dryer hotpoint nvlr333gt
it sounds like the back bearing or the iderly pully does it do it with a load and with out or it could be the the front pads i wish you luck if you give me the model number i might be able to send you the break dowmn of your dryer
[email protected]
rate this advise thank you
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
