Question about Goodman Heating & Cooling
We put in a new thermastat and now the ac wont work. Is there a fuse?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
R--redwire-power y-yellow wire -cool g-green---fan w-white -heat. If you turned it off &back on too fast, then you probably did blow the fuse on the outside unit or triped a breaker, check your fuse box ,or on the outside wall, theres a gray box called the disconnect box that sometime, house 2- fuses or a plain pull-out with no fuses.
Posted on Sep 04, 2008
Induced draft gas furnace will not turn work
Check the 3-5 amp fuse on the control board of the Furnace, tell me if the fuse has a burn spot on it.
Dec 19, 2012 | Heating & Cooling
Car keeps overheating
Assuming the engine is ok, no leaking head gasket or exhaust problem, you need to know if the radiator fan comes on when the engine reaches 225 degrees. It should also come on when you turn the ac on if the ac works.
Its also possible you have air in the cooling system.
Jul 20, 2012 | 2005 Dodge Neon
My AC Switchs wont turn on but the ac is fully charged and the fan works changed the thermostat and still the ac wont work..please help!!
The Thermastat has nothing to do with your AC becoming on at all because the Thermastat has to do with radiator fluids going into the engine to keep its high temperatures in check not your AC. You need to check the connection of the switch with a multimeter to see if current is getting to it and it is not then check the fuse for your AC in fuse box so see if this fuse is blowned. If the fuse is blowned tells me that there is a short in the wiring to the AC switch.
Jun 10, 2011 | 2005 Hyundai Elantra
Have electri heater. put in new honeywell thermastat programmable. did not hook up jumper wire like it said. now ac will not come on. if hook jumper wire, then both ac and heater comes on. whats the...
From end to end you have to put the red to red (24vac in), white to white (Furnace on wire), Black to common (24vac common), green to green (Fan On), yellow to yellow (AC On) and the jumper link back on. Also when you hook up the AC the two wires go, one on common (black) and the other on Yellow.
Looks like somehow you are picking up the AC & heater at the same time. If you need more info e-mail me at rspiak1@cogeco.ca
Jan 13, 2011 | Honeywell Programmable Thermostat Heater
2001 pontiac grandprix no blower heat/ac
how do i fix my ac/ heater they both wont work not even defrost it use to work only on selection number 5 now it dont work at all we just put a new blower in it today and it still wont come on
Apr 17, 2010 | 2001 Pontiac Grand Prix
Wall unit is only three years old pilot stays lit but unit wont fire up. even when disconected from thermastat and ttwo wires are put toether
Check for 24 AC volts out of the transformer. One side (typically white and black wire) you will get 110 volts and the other 24 volts all the time Yellow wires or two wires same color).
Jan 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
BATTERY WENT DEAD, CLICKING WHEN TRIED TO START IT. PUT NEW BATTERY IN NOW R WINDSHIELD WIPER WONT GO OFF AND AC WONT WORK
faulty windshield switch, if its does not go off the temporary solution is to remove the fuse/ ac not working, check fuse and ac relay
Sep 25, 2009 | 2000 Dodge Durango
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
My ac quit and heater wont work
it sounds like to need a new heater control panel.
Aug 02, 2008 | 1998 Ford Explorer
battery went dead because the rear windshield wiper didn't go off during the night, as soon as you put a new battery, the wiper start to working and won't stop. probably the switch out of order, A/C doesn't work, check the fuse.
Jul 27, 2008 | Dodge Grand Caravan Cars & Trucks
Heating & Cooling Logo
85 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
