Question about Konica Minolta DiMAGE A2 Digital Camera
What is the type of LCD monitor display? - Konica Minolta DiMAGE A2 Digital Camera
    Master:
  • 425 Answers
The DiMAGE A2 has a 46mm (1.8 inch) low-temperature polysilicon TFT color LCD Monitor, which displays approximately 118,000 pixels. This LCD monitor is tiltable (20 deg. downward and 90 deg. upward).
Posted on Sep 15, 2005
Th problem is lcd
No display on laptop's internal monitor, and there is no blinking cursor?
Start with seeing if it is a display problem.
Connect a VGA monitor to the laptop. If the display does not show on the external VGA monitor, the problem is the graphics chipset.
You did not state the model number of the Fujitsu laptop, therefore all I can give is generic basic information.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
This is an example of a VGA Cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector (Port) on your laptop is either on the side, or back of the laptop. May be marked on laptop as RGB.
You can use a CRT type of VGA monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
If not there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and at the same time tap once on the Display Toggle-Over key.
The Display Toggle-Over key is one of the F keys at the top of your keyboard. F1 through F12.
It will have a monitor symbol on it.
(For example most HP laptops use the F4 key )
No display on external VGA monitor? Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
If no display shows on the external VGA monitor you have a bad graphics chipset. Motherboard replacement.
If a display does show on the external VGA monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
Post back with the results, after using an external VGA monitor, in a Comment.
Regards,
joecoolvette
Apr 25, 2012 | Fujitsu Siemens Computers & Internet
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Jan 12, 2009 | IBM ThinkPad T42 Notebook
Philips 190B8 LCD monitor running under Win 2000 Prof OS
You need to get the inf file for your monitor to tell windows which monitor you have. did you get a cd with the monitor?
Apr 01, 2008 | Gateway FPD2275W LCD Monitor
LCD monitor
The DiMAGE E201 has a 46mm (1.8 inch) TFT color LCD Monitor, which displays approximately 77,000 pixels.
Sep 19, 2005 | Konica Minolta DiMAGE E201 Digital Camera
The DiMAGE A1 has a 46mm (1.8 inch) low-temperature polysilicon TFT color LCD Monitor, which displays approximately 118,000 pixels. This LCD monitor is tiltable (20 deg. downward and 90 deg. upward).
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
