Question about Dell Latitude C610 Notebook
UNABLE TO DOUBLE CLICK USING THE TOUCH PAD
I'M ABLE TO NAVIGATE THE MOUSE WITH THE TOUCH PAD BUT I CAN'T DOUBLE CLICK WITH IT OR THE BUTTONS. ANY SUGGESTIONS AS TO WHAT MIGHT BE CAUSING THIS PROBLEM? I EVEN WENT INTO THE CONTROL PANEL AND TRIED LOOKING AT THE MOUSE PROGRAM BUT I CAN'T CLICK ON THE TABS... THANKS FOR ANY HELP U MIGHT BE ABLE TO GIVE...MILDRED
  • 2 more comments
  • BossFan Nov 11, 2008
    Although its on a Lenovo T60. Sometimes, the buttons seem to work, sometimes both mouse buttons seem to act as the 'Right' or secondary mouse button. There is no pattern I can find yet. I tried playing with the control panel mouse features but to no avail.
  • Anonymous Jan 17, 2009
    I have a similar problem as you...
    I can navigate with my touch pad, but it will not let me double click.
    I can click with my buttons though...
    The strange thing is that just a couple weeks ago was able to double click with my touch pad.
    I tried looking in control pannel to see if I could fix it, but there is no touch pad options :S
    -Alyssa
  • Anonymous Apr 04, 2009
    Same. Unable to double click!
  • Anonymous Apr 07, 2009
    Same Here!
    I don't think its the speed!
    I already tried tat!
    Help Needed!
    THANKS IN ADVANCE!
You can solved this problem by following these: 1. Find the icon of your pointing device in the taskbar (mine is synaptics pointing device) 2. point to the icon and right-click on it. 3. check if "Tap To Click" option is checked. 4. if not, then click on "tap to click" option so that it will be checked. 5. try now to double click using the touch pad...and you will be okey now.
Posted on Aug 23, 2010
    Scholar:
  • 81 Answers
Go back to your control panel of your mouse; once there, in your pointer options menu, lower your speed of your cursor. Your speed might be set too high, and if it is, it will prevent your mouse from functioning properly, including not being able to click.
Posted on Sep 04, 2008
Update your drivers
--OR--
Use the Synaptics drivers, BUT you will lose the pointing stick.
Posted on Apr 12, 2009
4 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: right click not working
go into the mouse icon in the control panel and make sure its not disabled in there. If it is then enable it. If its not disabled in there then the board underneath your mousepad is bad. The right tactile button undernath the right mouse button is bad so the whole board would need to be replaced cause it comes as one whole board. You can get it directly from Dell or get one from Ebay.
Posted on May 26, 2009
  • 15 Answers
SOURCE: HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Posted on Sep 04, 2009
  • 53 Answers
SOURCE: My Dell Vostro A860 Touch Pad is not working
over the top of thetouch u can find a smaall button it could hav been pressed u release tat
then ur touch wil work
Posted on Mar 08, 2009
I HAVE BLOCKED MY CURSOR ON ACER LAPTOP BY MISTAKE
When your mouse pad is not functioning, it's hard to get most anything done on your computer. The fortunate side to all this is that getting a mouse pad to work again on a laptop is not an overly complex procedure. A few troubleshooting techniques will quickly lead you on your way to productivity again.
Examine your mouse pad. Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether. Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component. Check to see if your mouse pad has been turned off. If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad. To enable your mouse pad on a Windows PC go to the Control Menu. Under the Printers and Other Hardware option, click on Mouse. Then, click on the tab on the top of the pop-up menu that says Device Settings. The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work, proceed to the next Step . Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area. Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input. It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad). Then, click on download. Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again. Hope this helps.
Jan 08, 2013 | Acer Computers & Internet
CURSOR IS BLOCKED
Jan 08, 2013 | LG X-Note LM50 Notebook
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
Touch pad double click is not working. How to cure?
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Jul 09, 2012 | Dell Computers & Internet
Touch pad can't not function double click as enter
check the double click speed in control panel mouse properties buttons
maybe its to fast
or check the mouse driver options to see if th tap is enabled
Mar 28, 2011 | Computers & Internet
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
Mar 31, 2009 | Acer Aspire One PC Notebook
Touch pad not working
hmm... goto control panel, double click on mouse icon
click on Device Setting tab and Click on Enable button and finally................. :))
Thanks
Iqbal
Apr 06, 2008 | Acer Aspire 5630 Notebook
Double click problem
in most cases the best thing to do is to change ur mouse, but i would also suggest u try to use a mouse pad, some paints have a problem when using optical mouse
Feb 18, 2008 | Logitech LX7 Cordless Optical Mouse
Dell Latitude C610 Notebook Logo
3,778 people viewed this question
Alun Cox
