Question about Acer AL1916W 19" LCD Monitor
Wave motion on screen
Not even a year old. screen appears to have a faint wave motion. web pages are not distorted, its like a tall piece of glass with a thin sheet of water. just started doing this.
  • 1 more comment
  • ernde38 Dec 04, 2008
    Do you mean that there's a vertical section on the screen that flickers and distorts stuff, but when you take a screen shot, it doesn't show up on the screen shot, so it has to do with the monitor? If so, I have the same problem. Sometimes it goes away on it's own. If you restart, does it get progressively worse sometimes?
  • bussee Dec 09, 2008
    Mine is doing the same thing I believe. Its kind of looks like a 60cycle refresh rate on an old CRT monitor, but much worse. I have about 20 of these same screens and can switch the bad one out with an identical working monitor using the same power and VGA cable, and that one displays fine. It makes no difference If I move the bad monitor anywhere in the building, to any other pc or mac and it continues to have the scrolling horizontal lines. Any ideas? Its out of warranty
  • xx22 Feb 18, 2009
    I have an AL1912 that started doing that after the warranty was up. Sometimes it gets worse, like an old tube tv with the vertical hold scrolling upwards. I give it a few smacks on the top left corner, sometimes it helps, other times shut off the monitor and back on after a few seconds.
Two suggestions
!. Try changing your screen refresh rate. This might help.
2. Try turning off or unpluging any other equipment near the monitor like for example, fans, clocks, radios, etc.
Posted on Feb 23, 2009
It maybe an old laptop battery pack near it , i just changed to a new one and its perfect now , . it was driving me mental !"
Posted on Feb 09, 2009
  • 114 Answers
If it just started and you haven't changed anything such as graphics card or new video drivers, I would contact the manufacturer since you probably have at least a year warranty on the monitor. Also check that the cable from the computer to the monitor is secure. One other thing, make sure you have not placed anything that plugs into AC too close to the monitor as it may pick up the 60 cycle hum.
Lou
Posted on Sep 04, 2008
Distorted Picture
Problem is likely main board (processes all signals) or even the power supply board is possible.
Considering brand parts may be hard or impossible to find.
May 16, 2012 | Dell W4201C 42 in. Plasma HDTV
This D1025TM, horizontal distortion from active-off state
If it it part of a Win98 system that makes it well past its best, some20 years old.
Time for a new one.
Jun 24, 2017 | Dell 17" Monitor
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Wavy display issue ... please assist!
Feb 18, 2008 | Acer AL1916W 19" LCD Monitor
Moniter color callibration
Feb 17, 2008 | Gateway FPD2275W LCD Monitor
Distorted picture
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when doing tests. Best of luck, hope ya fix it.
Jan 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Enquiry
Does the screen seem like it's stretched top to bottom? Or does it have a wave like appearance when the object moves on set? Either way some resistance has changed. You may look at board and see a chardd or burnt spot near a resistor. You shoud have value checked and replaced. Also look for any caps out of line or distorted.
Apr 13, 2007 | JVC AV-48WP30 48" Rear Projection...
Acer AL1916W 19" LCD Monitor Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
