Question about Panasonic NN-S763BF Microwave Oven
Key pad is inactive
Light on... Screen shows "9sec... Press Start...P10" . All keys except Clear/Reset are dead. When Clear/Reset is pressed, it beeps and the screen turns to ":". Still the Clear/Reset is the only live key, and beeps when pressed. When pull the plug and reconnect, the cycle repeats. Thanks for advice!
  • Panasonic Master
  • 9,098 Answers
How long did you unplug it to reset it?
If you unplugged it for a good long time (minutes or hours) , then I would bet have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can order Panasonic parts here. Or you can contact your nearest Panasonic-authorized servicer.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 06, 2008
The start pause button does not work.microwave keeps running. Press clear/off
The key pad module is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 21, 2016 | GE Microwave Ovens
How to set clock
Press Clear (or Cancel). Press the CLOCK key (or the key that shows a picture or icon of a clock). Type in the time and press Enter/Start.
Aug 18, 2014 | Kenmore Elite Black 1.5 Cu. Ft. Convection...
How do I unlock the key panel
Opening the door while the oven is cooking will greatly shorten the life of the door switches and lead to failure.
Always hit "Stop" first unless the recipe calls for it.
The instructions for the child lock are in the owner's manual.
To set the lock, press Stop/Clear, then hold the "0" pad for more than four seconds. You will hear two beeps and the display will show "LOCKED".
To unlock, hold the "0" pad for more than four seconds. You will hear two beeps and the display will no longer show "LOCKED".
May 18, 2013 | LG LMVM1935 Convection/Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Screen says "locked" and nothing happens when you
    The child lock has been enabled on the microwave. To disable the lock, press and hold 0 until the Locked message disappears from the screen. To set the Lock, press Stop/Clear (to clear the display) and then press and hold the 0 pad until the phrase Lock appears and you hear two beeps.
    The manual for the microwave is available here: http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC8130DDS&siteCd=JA_EN_US&userType=Consumer . The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208112P218-60.pdf .
    I hope this helps.
    May 24, 2011 | Jenn-Air JMC8130DDS Microwave Oven
    Works fine, except the beeps suddenly went silent. Examples: 1. When food is finished cooking, no beep any longer. 2. When pressing any key to set for cooking, no beeps any longer. Never thought that...
    On page 21 of the owner's manual (online here), that's covered under "AUDIBLE SIGNAL ELIMINATION":
    If you wish to have the oven operate with no audible signals, touch CUSTOM HELP, the number 2 and STOP/CLEAR.
    To cancel and restore the audible signal, touch CUSTOM HELP, the number 2 and START/MINUTE PLUS.
    Feb 16, 2011 | Sharp R-1520LW 1000 Watts Microwave Oven
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    How do you reset the clock on the microwave
    press clear, press clock, enter time, press clock again.
    Dec 09, 2009 | Microwave Ovens
    I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
    The owner's manual is here. On page 10 we find:
    COOKING IN ONE STAGE
    1. Press the POWER button; the Microwave and High
    Cook indicators will light and “PL 10” will light in the
    display.
    2. Press the POWER button different times to set the
    desired power; the display will show the percentage
    you chose. If selecting power level 70%-10%, the
    Low Cook indicator will light instead of the High
    Cook indicator.
    3. Press number keys to set the desired cooking time.
    OPERATION(CONTINUED)
    4. Press the START/+30SEC. button to start cooking;
    the Microwave and one of the Cook indicators will
    blink and the display will countdown the remaining
    cooking time in minutes and seconds. It will beep
    five times when cooking is completed.
    Sep 08, 2009 | Emerson Microwave Ovens
    The keypad does not work. The display screen says "Press -----k". I'm assuming it's telling me to press clock to set time. But none of the keys work when I press any. Earlier only the Start/Pause key...
    try powering down for 30 seconds. if that doesn't work the keypad is shorted or open. do not spray cleaner directly onto key pad when cleaning. it will short it out. rather spray cleaner onto a rag then wipe.
    Jul 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Panasonic NN-S763BF Microwave Oven Logo
    440 people viewed this question
    Top Panasonic Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
