I HAVE A 10 YR OLD CARRIER HEAT PUMP.THE CONTACTOR POINTS WERE REPLACED TWO MONTHS AGO ,THEY ORIGINAL POINTS WERE PITTED AND NOT OPENING CAUSING COND. UNIT TO KEEP RUNNING.THE NEW CONTACTOR POINTS ARE DOING THE SAME THING AFTER TWO MONTHS. A/C TECH.DETERMINED THE COMP.WINDINGS ARE BAD CAUSING THE POINTS TO HEAT UP.WHAT DO YOU THINK I HAVE ACCES TO OHM AND MEGOMETER TESTERS. THANKS ALAN
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
First, check your compressor wires connections for loose or coroded, then clean them (file or sand them or just add oil to the ends connectors and go with a higher 24-va contactor instead of a 40-va, maybe a 80va 24-volt contactor.
Posted on Sep 04, 2008
I have a E2EH- 023HB Intertherm electric furnace. The contactors are sparking after furnace is turned on for a few minutes
replace contacters, probably old and pitted (remember points in the distributer on older cars?)
Feb 18, 2015 | Intertherm Heating & Cooling
Over heating. Radiator = 1 yr old. Head rebuilt
Try replacing the thermostat first. If it's new with the head job then try removing it altogether and see if that helps. New ones can go bad. Make sure it is installed with the coil down in the engine.
Is there any chance that silicone or form-a-gasket was used in the rebuild especially around a water jacket? Silicone can break off after the part is tightened and could be plugging a water passage.
When you redid the head was there a choice of more than one head gasket and did you compare the new with the old to be sure it was an exact duplicate? I would be extremely suspicious of either the wro ng head gasket or it being up side down.Either of these could block water passages and create your problem. Hope this helps.
Jun 22, 2010 | 1998 Jeep Grand Cherokee
Outside unit will not turn off
A couple of things can cause this;
the contactor points in the outdoor unit are pitted and sticking together, take the handle end of a screwdriver and tap the contactor, or turn off the breaker and see if the contactor points open. This problem can be frustrating as it can be hit and miss.
Even after this, if it is still running, disconnect the 2 thermostat wires, if it shuts off, you might have thermostat wires touching each other behind the thermostat.
Give this a try,
Good Luck.
Sincerely,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Carrier A/C making buzzer noise every 6 minutes.
Probably the contactor, they have a coil that sometimes buzzes, after the contacts become pitted and no loger pull together like they are supposed to. It could also be a voltage problem from the transformer that is causing it, but I would bet on the contactor. Get it fixed quickly as a voltage drop across the contactor can be the demise of you compressor!
Jul 13, 2009 | Heating & Cooling
New Goodman condenser unit run almost contiously using too much e
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
Jun 11, 2009 | Goodman Heating & Cooling
Goodman PGB042100-1 REVA Flame sensor not working; no heat
try national energy they will give you a price you will need make model and serial number 600 is high you should be able to get it for a lot less
Jan 07, 2009 | Goodman GMS90703BXA Heater
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
