Question about Maytag Neptune MAH5500B Front Load Washer
Door won't lock
My door won't stay lock so can't get the machine to go through the cycle
  • NANNA4 Oct 12, 2008
    I HAVE A OLDER FRONT LOAD NEPTUNEWASHER THE DOOR WON'T LOCK SO IT WON'T GO THROUGH THE CYCLES
I had the same problem, off and on for months. We walked through several of the solutions offered on this site with only slightly good results. Finally, we decided to bite the bullet and buy a new lock assembly. When my husband took off the front panel to install it, he noticed that the small electronic switch connection in the door lock assembly was not pushed all the way down so that the connection was tight. He "clicked" it in, put the front panel back on, and the unit locks and starts every time now!
Perhaps simply checking the tightness of the internal gadgets would save everyone some bucks!
Happy washing!
Posted on Dec 24, 2008
Mechanics at door appear ok, lock light remains dark, washer won't spin.
Front load #mah3000aww
Posted on Oct 12, 2008
  • 868 Answers
There is a very small chance the door latch is bad.My opinion with this model is your control board may be out.If your door does click in when you close it then the lock will will activate by the control board.If it wont click shut at all then of course it wont be able to lock.In this case you do have to change the "Door Latch Assembly". Please rate this !!!
Posted on Sep 04, 2008
4 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Door lock
Run a diagnostic on the door lock system; To place the unit in "service mode", close the door completely then press and hold both the "Delicates" and "Heavy Soils" keys for three seconds. Motor speed will be displayed. Press "rinse" to access the main board output function. Then press "max extract"... this is the test for the door lock. Did it lock? To exit, press "max extract" again and then both "Delicates" and "Heavy Soils" for three seconds. VOLTAGE TESTS AHEAD!!! IF YOU AREN'T SURE YOU CAN DO IT, THEN DON'T! CALL A PROFESSIONAL! If the door did not lock, you'll need a voltmeter and an hour or so. Open the door, remove the screws holding the door hinges, then remove the 2 screws (and shims) opposite the door hinges and close the door (do not take it off). Then grasp the front panel at the top near where it meets the top panel and pull toward you quickly. Lean it forward and remove it from the 2 clips at the bottom. Just below the top panel, now exposed, are the top panel retainers... use a 5/16" to remove the one screw on both sides and remove the retainer clips. Now lift the top panel up just like the hood of a car. You can now see the door latch assy. Remove the 2 wires on the solenoid and insert your meter probes into each one of them (color doesn't matter). Set your meter to read AC Voltage, then re-enter "Service Mode" and follow the steps to door lock test. When you hit the "Max Extract" key, 120 volts should be sent to the meter. If you get 120 volts, your latch assy. has failed and should be replaced. If you don't get 120 volts, your control board output has failed and needs to be replaced. Hope this helps.
Posted on Jul 29, 2007
watugot
  • 290 Answers
SOURCE: Door will not lock to start wash cycl
This sounds like a classic door lock problem. There was a design change in the lock assembly because of numerous problems.
You say you had the door replaced, did they replace the lock assy also?
The control puts power to the wax motor that operates the latch. As the door locks, the latch activates the lock switch that tells the control the door is locked.
What kind of reading are you getting on the lock switch?
Thanks/Mike
Posted on Nov 25, 2007
  • 90 Answers
SOURCE: Door Lock won't release.
pull your wire in soap dispenser to open door. You may have crimped a wire at door latch assy. when lowering top.
Posted on Jan 07, 2008
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Door won't lock / cycle won't start
Check if the lock is binding or the door switch is not being operated.
May 19, 2013 | Asko W6221 Front Load Washer
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Hotpoint WMA62 washing machine door won't release
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock.
Apr 24, 2012 | Hotpoint WMA64 Front Load Washer
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door won't lock..machine won't start
could be a faulty door lock as this is required to be locked before a signal is sent to the controller to start the wash cycle, try replacing the door lock, there quite cheal only a few pound
May 31, 2011 | Kenmore Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
599 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
