Question about RCA HD52W59 HDTV Projection Television
Im so sorry to bug you but i'm a single mom with no man around to help me figure this out.... My tv has the blue, green and red band at the top and a checked the menu button for the conv.(blah blah blah button) and found nothing. Is this to hard for me to do or should i look for a new tv?
  • 1,030 Answers
Ok if i understand you. you have enter the menu. then gone to setup in setup you have no convergence option. Has set been in shop before. sometimes tech turn it off but this is not a likely thing. the fuse is a technician replaceable item. it is not your standard fuse. you must be able to solder electrical components. but if you can find someone. or if you can solder. this would be a simple repair. BUT like i warn everybody this set gots some high voltage. so just be real careful.
Posted on Sep 05, 2008
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
Red distortion!
hello it sound like the convergance chips have gone to be fair the to the engineer its a big job
i hope you get it repaired good luck
Aug 04, 2009 | Televison & Video
Ps3 wrecked
it has a bug if it is a 40 or 60gb they are the ones that have it.
Jul 08, 2009 | Sony Playstation 3 (PS3) Console
I've got an RCA ctc195 series TV and the lamps appear to be working but the TV images are coming on with blue/red/green around the edges making them blurry - I know it's an old TV but I need it to work...
It sounds as if you have a convergence issue. If you go into the menue with the remote control
and highlite the screen selection. this should get you to the convergence selection. if you highlite
the RED selection and use the arrow buttons on the remote, you should be able to move the RED
either vertically or horizonally over top of the green line. Do the same with the BLUE selection.
If they do not move, you probly have a failure with the Convergence power Supply. To my knowlege, that board is no longer available and you would need a professioal Service tech to repair the board.
Hope this helps,
Jun 16, 2009 | RCA P56950 56" Rear Projection Television
TV Has grean red and Blue lines going through it.
Yes this can be fixed. It is a common problem caused by a failure of the "convergence" circuit. Sometimes in this particular set, just a bad solder connection can cause this (though no shop will admit it). Other times its just a simple part on the Deflection board. The repair should run around $300
Mar 20, 2009 | RCA P52926 52" Rear Projection Television
No headlights
I found the connectoers to the headlights to be un weather proofed. I went to auto zone or advance auto to buy replacement connectoers, The replacement I bought had 3 wires, Black, Red, Green, and they have a rubber protective boot so as not to fail again. Turn off the car and disconnect your battery.
1. Pull the plug on the headlight
2. cut the wires
3. Black to black, blue w/red stripe to green, and blue to Red. I would use **** connecters with a heat shrink, or just tape really good with black electrical tape.
4. plug new connector in to headlight and test. Should be ok now.
Mar 13, 2009 | 2001 Kia Sportage
Could you tell me pls where the factory reset button is ?
its on the side of tv! but 1st take on the black lable on the back than push that button in than the red green and blue will can on ones done put black lable back on and thats than good luck
Dec 30, 2008 | Samsung SP42P2S Television
Around edge of tv the colors blue/red/green/blurry...
my 52" rca tv just started showing blue red double pictures yesterday...covergence don't show up on the set up menu anymore so i can not do much will it cost to fix this problem?
Nov 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a ws-a65 tried to install 1080 hd quality through At&t u-verse missing green and red color only shows yellows and blues help!!!
im just going to assume you have it hooked up wrong, call a TV person and they can come look at it, its really hard to do this kind of thing over the internet
Oct 08, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Picture is Distorted, red/green/blue curves
you have bad convergenze this fault is common and need qualified person to change the STK ic's call repair man please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Sony KP-51WS500 51" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
