Question about Dryers
Dryer motor is squeaking - Dryers
  • 374 Answers
Most electric motors do not squeak perse. I suspect the culprit is a worn out drumretainer bearing and or retainer assembly. This is the device that is mounted on the back of the drum and back of the dryer cabinet to hold the drum level and centered. It could also be the belt especiallyif the motor has become out of alignment from a broken mounting bolt if your unit is in a high moisture concentrated area.
Hope this helps.
Posted on Sep 04, 2008
Dryer is squeaking bad
its either the belt slipping .... the motor ....... or the main drum bearing you can take the belt loose and spin the drum and listen for the squeak then spin the motor and listen that should tell you which is causing the squeak
Mar 26, 2012 | Washing Machines
Dryer was squeaking and now it just clicks when you push the start button
if motor will not run. check it out! it may be seized or in need of oil on end bearings. ( each end of motor ) just get access to the motor.
Feb 01, 2012 | GE Dryers
Dryer making squeaking noise, what causes this?
The squeaking could be coming from the idler pulley on the motor, the drum rollers or a worn drum seal. It is not a good idea to spray the rollers with WD-40. The WD-40 will attract lint that will build up and could catch on fire inside the dryer cabinet. A bad drum support roller or any other squeaking component inside a dryer cabinet will normally need to be replaced.
Aug 29, 2011 | Maytag Neptune MDE6700A Electric Dryer
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
The dryer squeaks when first started, then is
the belt that connects the motor to the drum needs replacing
Apr 28, 2010 | Frigidaire Electric Dryer
The dryer squeaks as if a bearing needs grease
Most likely cuprit for a squeak in a dryer is the belt tensioner. Most dryer have them mounted in the base in front of the motor. ( not the easiest thing to get at most times)
Apr 03, 2010 | Bosch Nexxt 500 Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Dryer squeaks when drying clothes
try letting the mouse out??? its likley to be the drive belt or rear bearing dry,,, could be the motor bearings dry,,
back bearing and motor bearings could be lubed with WD40 but dont put it any were near the drive belts as they will then slip like mad,
spray on the driv belt a bit of "stop squeak" its for car fan belts realy but it works on any rubber belt
Oct 24, 2009 | GE DRSR483ED Electric Dryer
Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
May 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Bosch Dryer squeaking noise
I have not seen any service manuals online. The squeak will possibly be a rubber bush used to silence the machine. If you get it stripped down you should be able to locate the squeak by carefully applying pressure in different areas and the squeak should go... then hopefully you will have found the culprit.
Mar 15, 2008 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
614 people viewed this question
Top Dryers Experts
