Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Moisture behind screen
My son sprayed windex on the screen and it looks like it got behind the screen and is spreading up. What should I do?
  • 505 Answers
It is difficult to clean/remove the screens. Best case senario, it will dry up leaving little to no water mark. There are three screens, liquid gets between them and it sucks it in. Disassembly and cleaning will fix, but the screens are very fragile and cannot be wiped without potential damage. Any dust, dirt between them will show in the picture. Proceed at your own risk.
Posted on Dec 07, 2008
Windex lcd screen
hi
i use it all the time but i spray it on the cloth
i dont spray it directly on to the lcd screen
i do it when its off not on
aries
Nov 14, 2013 | Computers & Internet
My Pioneer VSX 820K will not turn on. Son sprayed some windex on it when it was on and it shut down.
More than likely the windex fried a channel or two. If you have a DVM you can find out wich chanel or channels is bad by checking each output transistor for each channel until you find the one that is shorted.
Jun 06, 2012 | Pioneer VSX1020K Receiver
I was windexing the screen when i noticed the it was seeping in behind the screen. now i have windex behind the screen in two large clumps and it looks bad. i tried a blowdryer, all the did was heatup the...
Do not ever use anything other than warm water and a soft rag to clean your LCD screen!!!!!
Possibly use a little mild dish soap on a damp rag, but make sure the rag is only damp.
You have now ruined your screen and most likely will need to replace it.
Apr 23, 2011 | Toshiba Satellite A215-S7422 Notebook
Cleaning the scaner window.
Since it is glass, you should be able to use a mild cleaner like eyeglass cleaner. Also, glass cleaner like Windex should should, but you should remember to spray the cloth and then wipe, not to spray the scanner as the moisture could mess with the electronics.
May 04, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Cob webs behind screen
The frame around the screen just pops off. Unscrew the plastic holders from the chassis frame and the screen will come off allowing you to clean everything inside easily. The "2" thin screens are easily cleaned and put back on easily also. Don't do what I did and think the screens go into the front slot of your plastic brace, they slide easily into the wider slot. You'll also be able to clean the dust from the reflector and guns with Windex. Much better picture after wards, trust me. You would be surprised how much dust may have accumulated on the lenses.
Jan 31, 2010 | Philips Magnavox 55P9271 55" Rear...
GPS touch screen sprayed with Windex; doesn't work.
After reading sharcnet's reply yesterday that putting the unit in the freezer was absolutely the wrong solution, I was very panicked! However, once the unit thawed out it worked fine. We tried the freezer because we've used that tip before to "freeze-dry" cell phones that got wet. Luckily the LCD was not damaged & everything is working fine now. And my husband knows not to spray Windex on any electronic screen!
Jun 01, 2009 | Garmin nuvi 255W GPS Receiver
I sprayed windex on my ps2 slim lens how do i fix it
Try carefully cleaning the lens with Isopropyl alcohol on a Q-tip. Any film left behind from the "Windex" may have caused distortion, or refraction of the lazer. Worst case scenario is that you may have been too vigorous cleaning the lens, and it may be out of alignment now.
Feb 11, 2009 | Sony PlayStation 2 (PS2) Console
Wet rear projection sceen
You may be able to reach it through taking off the back cover and wiping the screen down. If not you will have to remove the screen assembly.
Jan 20, 2008 | Panasonic PT-53TW54 53" Rear Projection...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
