Question about Konica Minolta DiMAGE A2 Digital Camera
Which types of filters can be used? - Konica Minolta DiMAGE A2 Digital Camera
    Master:
  • 425 Answers
Please use thin type filters to prevent vignetting on the corners. The following filters are vignetting-free. Konica Minolta 49mm AC L37 (UV filter) (Thickness is approx. 5.5mm in total, and approx. 3.4mm excluding the screw part.) Konica Minolta 49mm ND 4x filter 49mm type causes vignetting. Please use Konica Minolta filter adapter (49mm > 62mm) and 62mm Polarizing filter II (Circular) in combination.
Posted on Sep 15, 2005
Where is fuel filter on 2010 chevy express 6.0 liter V8.
2 of them........First Fuel Filter
One fuel filter is in the fuel pump of the Express Chevy 3500, which is used to push fuel or gasoline through the fuel line. The fuel pump is inside the gas tank. This fuel filter is a mesh or screen that prevents large foreign particles for entering the fuel pump. Access to the fuel filter is obtained by removing the fuel tank and then the fuel pump from the fuel tank.
Second Fuel Filter Location
The second fuel filter is within the fuel line itself. After the fuel pumps extracts fuel from the gasoline tank and into the fuel line, fuel flows through the line and through another filter on the driver's side of the Express Chevy 3500 under the front wheel suspension. This fuel filter cleans the small particles that escaped from the fuel tank.
Fuel Filter Types
The year of your Chevy Express 3500 determines what type of fuel filter is installed on the van. The fuel tank filter is always mesh or screen, but the fuel line filter can be of three different types. Two types are snap-on filters, while one type has clip-on ends.
Jan 25, 2018 | Cars & Trucks
Are there different types of coffee filters?
Yes, there are a few types of coffee filters.
I would recommend using paper filters. They are widely available, easy to use and are comparatively inexpensive. The best part of a paper filter, is that they are disposable.
If you would rather not use a paper filter, another popular option would be cloth filters. If cared for properly, these filters can last anywhere from 3-6 months.
Other varieties include metal, plastic and glass filters.
Feb 07, 2013 | Wine & Spirits
Cannot remove oil filter toyota pickup
As a last resort, yeah, a screwdriver. What about a strap-type remover? Large channel-lock pliers? Make sure not to over-tighten new filter. Good luck.
Oct 29, 2011 | 1989 Toyota Pickup SR5
What size or type tool use to remove cover of oil filter housing and do you have to remove oil filter housing FROM the engine? THIS IS A 1998 MERCEDE BENZ E320
no you don't have to remove the oil filter housing. Mercedes Benz has a tool that fits right over the oil filter cap that is inexpensive or you can just use a oil filter wrench. On the in-line 6 cylinder motor its a little harder to fit a filter wrench back there so a claw type filter wrench might be easier to use.The Mercedes filter tool can be found online also.
Sep 27, 2010 | 1998 Mercedes-Benz E-Class
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
How do i change the fuel filter in my 1985 cadillac deville (gasoline)
FUEL INJECTED ENGINES The fuel filter on fuel injected vehicles may be located in one of two locations. On all 1976–79 vehicles except the Seville, the filter is mounted in the engine compartment near the fuel pump. On the 1976–79 Seville, and all 1980–85 vehicles, the fuel filter is located on the left side of the chassis just ahead of the rear axle. On 1986–89 vehicles, the filter can be found near the frame, in back of the left front wheel. There are two types of fuel filters used on the gasoline fuel injected vehicles, the one-piece disposable inline filter, used on all 1982–86 250 and 1988–89 273 V8 engines, and the replaceable element type filter used on all the other engines. CAUTION
Fuel is under high pressure: if the steps below are not followed, the fuel could spray out and result in a fire hazard and possible injury.
  1. Disconnect the negative battery terminal.
  2. Release the pressure from the fuel system:
    • Without pressure fitting: Cars without a pressure fitting in the fuel line, cover the fitting to be removed with a shop towel while loosening so that fuel will be absorbed. Dispose of gasoline properly.
    • With pressure fitting: Locate the pressure fitting in the fuel line and remove the protective cap. Loosely install a special valve depressor (G.M. tool no. J-5420) on the fitting. Wrap a towel around the fitting to block any spray and slowly tighten the tool until the pressure has been relieved.
  3. Replace the filter as follows:
    1. On the replaceable element type filter; the fuel filter element is replaced by unscrewing the bottom cover and removing the filter element. Replace the element and gasket with an AC type GF 157 or equivalent. Hand tighten the bottom cover.
    2. On the in-line disposable type filter; the fuel filter canister is replaced by loosening the fitting on the end of the filter, then use a pair of pliers to expand the clamp on the other end and slide it down past the point where the hose extends over the inlet of the filter. Gently twist and remove the hose, unscrew and remove the fitting. Remove and discard the old filter. Install the new filter into the hose and replace the clamp. Reinstall the fitting, and check for leaks with the engine idling. NOTE: A dry fuel system on cars equipped with EFI/DFI may require a substantial cranking period before starting. Be sure to crank the engine in short bursts, allowing time for the starter motor to cool between each burst. Fig. 1: Fuel filter location, disposable type — 1986–87 8-250 and 1988–89 8-273 engines 85871013.gif
      Fig. 2: Fuel filter location, sealed type — 8-250 and 8-273 engines 85871014.gif
      Fig. 3: Common fuel filter location — lower right corner 85871093.jpg Fig. 4: Removing the fuel filter hose clamp 85871094.jpg Fig. 5: Removing fuel filter lines — always use a back-up wrench 85871095.jpg Fig. 6: Removing fuel filter mounting 85871096.jpg
Jun 29, 2010 | 1985 Cadillac DeVille
Where is the fuel filter on Chevrolet 1993 S-10 Blazer
Inline Filter Some trucks may have an inline filter. This is a can-shaped device located in the fuel line between the pump and the carburetor. It may be made of either plastic or metal.
Internal Filter
Two types of fuel filters are used, a bronze type and a paper element type. Filter replacement should be attempted only when the engine is cold.
In-carburetor fuel filter
Cartridge Type
The cartridge type fuel filter is located along the frame rail
Except Cartridge Type
Fuel filter location mounting and lines
The fuel filter is found along the frame rail
May 05, 2010 | 1993 Chevrolet S-10 Blazer
What type transmission fluid do i use in a 2006
use dextron 6 transmission fluid -- recommend using fram transmission filter kit
Dec 01, 2009 | 2006 Jeep Liberty
Is there special tool to get the oil filter cap off on a 2007 Fusion with a cartridge type oil filter
YOU CAN USE A CUP-TYPE OIL FILTER TO REMOVE THE HOUSING AND SLIDE THE OIL FILTER OFF THE STEM. BE SURE TO REPLACE THE O-RINGS. I HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. BEST OF LUCK
Aug 26, 2009 | 2007 Ford Fusion I4 SEL Sedan
Filter Cleaning
Depends on what type of filter you are referring to. If it is a fabric type filter media these are throw aways. If it is an electrostatic filter you should buy a spare. Wash one use it for 30 days then replace with the spare. Vice-Versa. These need to completely dry before they are put into use.
May 27, 2008 | Carrier Heating & Cooling
Konica Minolta DiMAGE A2 Digital Camera Logo
70 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
