The brushes will not turn. Is there a belt or something to drive them and are instructions for repairing them available? Everything else seems to work well.
There is no belt in a Hoover SteamVac. The brushes are turned by an air driven turbine. If the brushes are not turning, it is usually because the turbine has seized up and may need replacement. Insert a screwdriver into the square hole that the pin on the brush assembly normally fits into and see if it turns. If it doesn't, you will need a new turbine.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer.
The belt is stretch and so it is slipping on the motor shaft. You need to change the belt. Here is a link for the
instructions on how to change the belt and a link for the belt you need:
Hi
If your Dyson has a brush protection design - i.e. roller bar on the top of the hood on the left hand side then the DYson can't be repaired by you- serviceman or professional care can replace it.
However if the Dyson doesn't have the roller bar on top of the hood, flip the machine over so that the beater brush is facing upwards, locate three/four screw heads that can be undone with a coin and remove the sole plate assembly. This should give you a clean view of the brush bar, drive belt and dirt channel. Ensure everything is clean espcially if the brush bar has lots of hair or threads tightly corded around. Then locate the drive belt and check to see if it has snapped. Grasp the beater bar gently upwards and the belt and brush can then be removed. Fit a new belt on carefully and check the tension as it will be tight.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. [email protected]
You need to change the belt. The belt will not turn the brush roll and is slipping on the drive shaft. This is creating the burning smell you describe.
You say you just brought it home.From where? From repair or is this a new machine.
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Check the belts, there ia cogged belt that drives the brush roll. Turn the unit over, take out the one screw holding the red lock, pull that off then the cap for the brush roll will pull out, remove the cap and check the belt, also check the pulley on the end of the pump to make sure that it still has cogs on. If there are no cogs, then you will have to replace the pump. While you have the brush roll out, make sure the it looks ok on the end and not melted. This would also be a good time to replace the **** belt if it needs it.
