Question about Pioneer DV-588A-S DVD Player
Lost pink component of color
My TV set is OK in full color. But the DVD player, once after a long time not in use (beroreit , it has been always OK during1.5 year), started to loose pink component of color: the opening screen has the word PIONEER in pink on black backgound, but this time it appeared gray, and movie heroes looked like dead with yellow-grayish faces and bodies. I turned the player off, waited 15 to 20 min., then turned it back on; first 5 minutes, the pink component was present, then disappeared again into gray. Repeated attempt gave same result.
  • speravy35 Sep 04, 2008
    You suggest that only after 18 months of VERY MODERATE usage (3-3.5 hours/day, and even not every day) of a new DVD player, the lens may be weared out?? I cannot believe it.
  • 624 Answers
The problem is not the lens, it reads the disc, the lens is OK. The problem you have resides in the video codec circuit, this is not anything you can fix yourself without some good knoledge of electronic troubleshooting and the proper test equipment. Even after a few months this can happen, it is a random part failure that is not common, but can happen. You just had some bad luck with this unit. You can take it in for repair, but it will cost you over $100 to get it fixed. If you paid less than $200 for it, you should just get a new one.
Sorry for the bad news, but it is the most likely problem with it. I fix these for a living, so I am not just guessing at the problem.
Good luck, and let me know if I can be of any more help for you.
Posted on Sep 04, 2008
    Brigadier General:
  • 6,966 Answers
Your post is descriptive:
  • it is not a lens reader problem since the firmware display (Pioneer logo at startup) also looses color;
  • it initially seems to be heat related;
  • pls check if it has a switch for PAL/NTSC. try switching over repeatedly if it has one;
  • you may need to open the unit and check internal components. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 521 Answers
The lens which is reading the disk is replace the lens of the cannot be repaired .and replacing is near to the cost of you think what is better for you,as i suggest go for the new device.
pls do rate the solution
fixya expert team
Why does my emerson 32In TV not find a channel for the DVD player that is running?
Check all the input connections once again. Check input cords. Change the cord and check. Sounds you have connected it to receive signals as AV. Select the input at TV to AV. If colors of the wire connected doesn't match the colors of the sockets at both TV and DVD end; this type of fault can occur. Anyway, check the connections and the colors of socket & wire do match, once again.
If all are found ok; and still you do not get signals, the main board to your TV should be troubleshooted. Contact any service technician.
Electro help
Feb 07, 2015 | Emerson Televison & Video
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
I just got the Toshib 46rv530u and can't figure out how to get it to change video to 1080p
1080p full hd video can obtain only through hdmi. for that u need a full hd blue ray player or full hd sat receiver . the tv automatically changed to full hd according to the input connecting to it .go to hdmi setting and check whether hdmi connectivity is ON. also check the hdmi setup of ur input device.
Dec 16, 2010 | Toshiba REGZA 46RV530U LCD TV
The colors are looking strange when the DVD plays. The colors look blue, neon greenish-yellow, but no reds. The colors are perfect when tv is on, but dvd screen, once movie begins, has strange colors. ...
Try placing the dvd-player as far as you can away from the TV. It may be creating EMI (electro-magnetic interference). Ensure that the wires from the DVD-to-TV are not positioned close to other electronic devices -try moving them.
You say the TV works fine on its own, so that is good; there is probably no big magnet or speaker near the TV.
If it is not anything external causing interference, then yes, your DVD player is probably malfunctioning. Try borrowing a friends..
Aug 30, 2009 | Panasonic DVD-RV32 DVD Player
Need code to adapt to Toshiba HD flat screen TV
If it's a regional code that you're looking for
Switch player on and make sure there is no disc in the tray.
CLose tray and press menu,1,9.
A menu should appear with the region option at about the third line from the bottom. Press enter and enter the region you want. Press enter again to memorize the code. Next press open/close. Put in your movie and enjoy.
if your movie starts playing in black and white:
To always watch in color if you do not have a Multisystem TV set Video output to Your TV system USA TVs- NTSC, Europe TVs PAL. This way You should always get color on Your TV
Hope it's what you were looking for. Good luck!
Mar 30, 2009 | Cyberhome CH-DVD 300 DVD Player
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
if the tv is showing the same worse quality without connecting any external device.then its the tv problem.and new tv is much advisable.
Nov 23, 2008 | Televison & Video
Sony DVD player color adjustment (Model #DVP-N5400D)
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either: 1) the cables from the DVD player to the TV or 2) the DVD player is the problem So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway.. At least I didn't have to buy a new DVD! Lesson: unplug, re:plug...before you trash it!
Mar 06, 2008 | Televison & Video
Pioneer DV-588A-S DVD Player Logo
64 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
