Question about Sharp (BQCXGC50X1) Projector Lamp for PG-C45X, PG-C45S, XG-C50
XG-C50 I have a Sharp Notevision XG-C50X that strikes the lamp and then after about a minute the lamp goes dark. The green lamp indicator blinks green and after about 30 seconds you hear a relay and the lamp re-strikes. The on off cycle repeats about 3 or 4 times and then the lamp indicator goes red and its game over until you reset. I replaced the lamp but the problem remains. All the fans are spinning and it really never has a chance to get overly hot for the short amount of time the lamp is lit. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Pls check the fans under the Optical Engine, under the prism
the fans easy to be failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Posted on Aug 26, 2016
4 Suggested Answers
dhiman
  • 115 Answers
SOURCE: XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Posted on Jan 21, 2008
SOURCE: light on my sharp xg-nv4su projector comes on for
To reset the lamp timer you:
1. Turn off the main power button on the back of the projector.
2. Hold down the down, right, and enter buttons on the projector.
3. Turn the main power button on the back back on.
4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
Posted on Oct 12, 2009
  • 1833 Answers
SOURCE: I replaced the lamp in
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
Posted on Feb 21, 2011
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Sharp XG-C50X Notevision. Doesn't get past "warming up"
it seems that the powersupply is failed
Have a nice day!
Jerry
Lampdeng Limited
Nov 21, 2009 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Sharp XG-P10XU lamp problem
power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
Having problems with my sharp notevision XG-C40XE
Your lamp is not lighting up most likely. Try removing the lamp assembly and clean the contacts. If that does not work then you will probably need to replace the lamp. Also try resetting the timers. Refer to you owner's manual for info on how.
Aug 23, 2007 | Sharp Notevision XG-NV6XU Multimedia...
Sharp Notevision 6 XG-NV6xU
reset the lamp hours on your projector
Jul 28, 2007 | Sharp Notevision XG-NV6XU Multimedia...
XG-C50 Problem
Hello
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Sharp (BQCXGC50X1) Projector Lamp for PG-C45X, PG-C45S, XG-C50 Logo
135 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
