Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Not hearing the buzzing
The tv won't turn on and the lamp light blinks...however, I don't hear it clicking or buzzing...could it be something other than the bulb?
please respond to clokane24@hotmail.com
  • cokane343 Sep 04, 2008
    also I've noticed issues with the blue blob...the optical block issues that i have been reading about....could my lamp not turning on be corralated to the optical block issues? both happened all of a sudden....
    Novelist:
  • 135 Answers
It's a lamp.
The blue blob is an optical block issue. Contact Sony for repair.
Posted on Nov 09, 2008
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
LED light blinking 6 times and TV won't turn on
When you turn on the power button listen to the back of the TV, you should hear a motor with a high pitch spin up (the color wheel) and then the lamp should attempt to fire. The lamp should make a sparking sound and if it does your lamp is most likely defective. The part number for the lamp is on a sticker on the sode that will say "Lamp Code" on it and will be something like BP96-****
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
When I try to cut on the TV all 3 indicator light start to blink.
listen to the tv from the rear you should hear a slight wind up of the colorwheel just after the power button is pressed. after that the lamp ballast should attempt to start the lamp . if the lamp is bad you will hear a buzzing and see no light coming from the lamp door. if you dont hear that winding up of the colorwheel its bad and needs to be replaced
Feb 01, 2010 | Samsung 50" Slim-Depth DLP HDTV
Picture suddenly went out and the lamp and temp lights in front circle are blinking.
Hi,If your tv is between 2-4 yrs most likely it's time to replace the lamp.If you hear continuous clicking it could be the ballast which is the board that powers the lamp.If you hear buzzing it could be the color wheel,which is a spinning wheel that creates the color on your tv.God bless you!
Oct 13, 2009 | Samsung HLN4365W 43" Rear Projection...
No picture and blinking light consistently
Do you hear clicking or like wanting to turn on? it could be the ballast which is the board that powers the lamp .Do you hear buzzing ,whirling or like a high pitch sound? If you do it could be an issue with the color wheel.If you don't hear any of that and tv is between 1-2 yrs then most likely it's the lamp that needs to be replaced.Your Original lamp is Osram and last 4000-5000 hrs, get the Philips which will last 2-4 yrs 6000-8000 hrs.God bless you!
Oct 01, 2009 | RCA Televison & Video
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
Jun 28, 2009 | Televison & Video
Tv won't turn on red lights blinking
You are hearing the spark gap mounted on the lamp ballast board. If you can hear that sound, that means everything in the lamp driver circuit is working except the lamp!
Get a new lamp.
michtech
Jan 31, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv work come on , all 3 lights blinking
All 3 leds blinking is a Lamp error. Pull the lamp and see if it is blown. If so, replace. This error can also be caused by many parts of the optical block = colorwheel, balast, or DMD board. If you hear a buzz sound when it tries to fire lamp then the lamp is bad. If not listen for the spinning high pitched squeel of the colorwheel coming up. If you hear this but no buzz from the ballast, you likely have a bad ballast. If you do not hear the color wheel, you have a bad color wheel or DMD board.
Dec 07, 2008 | Akai Televison & Video
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
43 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
