Question about Dell W4201C 42 in. Plasma HDTV
Dell Plasma 4201c
Hi, I've been reading your post and you make good sense. I wonder if you can help.
My problem started with a 3rd of the screen going black. Then I heard a snap and no pic or sound. The green light is on in the back and the blue light comes on by the manual buttons. I took it to a repair place and they went to replace the main board, then then found a bad Y board. They said we can keep going on replacing parts but it will be too expensive. They took out the new main and put back in the old. What do I do and where do I start. I see a few of these boaqrds on eBay, I figure I can replace a few and see what happens, but I'll need your guidence.Is there a tech sight on Dell for trouble shooting. Please Help me. Thanks!
  • 51 Answers
Hello everybody!
I have solution for common problem with Dell W4201C. There are two Y Buffer boards that are failing and could show problem as bunch of horizontal lines or even dead set.
I do have boards in stock. If you need them, please contact me at plasmatech@gmail.com
Posted on Oct 23, 2008
  • 3,940 Answers
There is no Dell tech site for servicing the TV, there are no user servicable componets in the TV.
If the TV is uneconomically repairable, then I'd say cut your losses and buy a replacement.
I wish I had better news but with the cost of repairs increasing and the cost of replacements dropping older TV's are quickly becoming disposable rather than repairable.
here is an example:
http://www.jr.com/panasonic/pe/PAN_TH42PX80U/
Posted on Sep 04, 2008
Dell 4201c won't connect to ps3
You might be better served to post this in the computer area as it seems like a mismatch of some sort exists---I have heard the dell issues before.
Dec 23, 2012 | Dell Televison & Video
Where and whats is involved in removing the bulb from a dell 4201c hdtv plasma 42"
If it is a flat panel plasma tv there is no lamp (bulb) in this type of set. Only rear projection LCD and DLPs have Lamps that need to be replaced.
Aug 11, 2011 | Dell W4201C 42 in. Plasma HDTV
Dell 4201C Plasma 42" -
Hi, Mary.
This sounds to me like it is a bulb issue, and not something worse, like failed capacitors.
If that is the case, then yes, it is worth repairing it.
You need to get the old bulb out, either by removing it yourself, or by having someone take it out for you, and the take the old bulb to Fry's or BestBuy.
They both keep tv projection bulbs for flat screen tv's in stock.
I hope that I've helped you understand what is going on, and that it helped.
Have a nice day, and good luck.
Mar 14, 2011 | Dell W4201C 42 in. Plasma HDTV
Dell 4201C has blue power light but no picture/sound
HI...
Failed main power supply.
Check the web for service near you
Oct 07, 2010 | Dell W4201C 42 in. Plasma HDTV
Buying Dell Power Supply for 4201C Plasma
You can get it from guy at
He has everything for Dell TVs!
Nov 19, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell Plasma
yes i still repair dell 4201 plasmas. i have repaired over 100 of these units. im familiar with them.
Sep 04, 2008 | Dell W4201C 42 in. Plasma HDTV
Power Supply
bad power supply take it to a repair center cost about 30-60
Aug 31, 2008 | Dell W4201C 42 in. Plasma HDTV
Help
the problem can be traced from the power bd. you will need a digital volt meter. There are settings located on a sticker located on the upper right corner Va,Vset,Ve, Vset etc..... each one has a DC voltage. compare the voltages to trace the source. My suggestion from experience is the Y Main upper or lower buffer which ever has a brn mark located on the metal of the panel. Google a local dell dealorship or a repair company in ur local area, and get serviced.
Jul 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell 4201c power problem
I am an actual Dell repair tech for a non-Dell refurbishing company. I fix this model exact model, as well as all the other plasma TV's that Dell has come out with. If you are looking for a replacement part I suggest starting with either the power supply. But if you are electronicly inclined, I suggest taking voltage measurements across the labeled parts on the power supply that are the following: VS, VSCAN, VSET, VE, and VA. These correct voltage measurements are labled on a sticker in the top right corner of the TV. If they all come out right then your best bet would be the Y-main board with both upper and lower buffers. They are the circuit boards on the left hand side of the TV. As far as getting the parts, thats a whole other story but I hope this helps to narrow down your parts search.
Feb 03, 2008 | Televison & Video
Dell W4201C 42 in. Plasma HDTV Logo
219 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
