Question about Fuji FinePix A345 Digital Camera
STUCK ON STANDBY
WHEN I TURN ON MY CAMERA IT IS STUCK ON THE "STANDBY" MODE.  I SWITCH IT TO "CAMERA" AND IT STILL SAYS "STANDBY".  I CANNOT TAKE PICTURES OR DO ANYTHING.  I HAVE REMOVED BATTERIES AND REPLACED WITH NEW AND NOTHING CHANGES.
  • GURBACHAN SINGH AKAL Sep 20, 2008
    I have brand new A345 FINEPIX,used a couple of times.All of sudden its LENS is Stuck and is not opening.Will some body help me troubleshoot this prob.Screen shows 320
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Posted on Oct 15, 2008
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
Mar 03, 2015 | Televison & Video
Nokia C3-01 Camera on standby
I have problem with camera operation failed in my nokia C3 01. I can`t take the photo at all. i don`t know why like this.When i start camera of nokia c3 01 ,it show operation failed and Camera on Standby
May 19, 2012 | Cell Phones
Samsung digimax d53 is in standby mode cant take pictures
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Jan 03, 2010 | Samsung Digimax D53 Digital Camera
When I turn on the camera, nothing happens and the screen/view finder is blank. i checked the standby switch its off. when i press record it will record but on the tape it is just a black screen? any ideas...
i know exactly whats wrong! the same thing happend to me.
1. turn off the gl1 2.look at the record button with the lock and standby switch 3.flip the switch all the way to standby because it might be stuck in the middle 4. turn on your camera
Dec 03, 2009 | Canon GL1 Mini DV Digital Camcorder
My GL2 only works when I turn it on to playback mode. When I try to turn the camera on in camera mode, it doesn't work. What could the problem be?
There is a simple solution to that... You see under the 'card-tape' switch? There's the red button for recording... attached to that button the is a switch that says 'tandby or lock'.... if you have it in 'lock' it will not let you go to record mode, you have to change it back to 'standby' and that should solve your problem.... Anymore question just e-mail me at Jacob.Bahling@Live.com and I was wondering if you had a copy of the installation CD I can buy or have.... or maybe you could tell me where to get it? Thanks.
Sep 26, 2009 | Canon GL2 Mini DV Digital Camcorder
Nikon sb-27 speedlight appears stuck in standby mode
Buy a Yongnuo flash. They are great replacements and are inexpensive.
Dec 14, 2017 | Nikon Speedlight SB-27 TTL Flash
It is not switching on
1. Please male sure that the battery is inserted in the correct orientation
2. For laptops, make sure you have checked the Power Options settings.
a. Hibernate should not be set.
b. Monitor, Hard Disks and System standby should be set to NEVER
3. For desktops, turn off computer's hibernation, standby, and sleep modes.
4. Turn off the camera
5. Connect the USB cable from camera directly to the computer's USB port
if the issue is not resolved, contact kodak at www.kodak.com/go/itg
Jan 22, 2009 | Kodak EASYSHARE M763 Digital Camera
Stuck in standby
what kind of batteries do you have
Sep 25, 2007 | Fuji FinePix A360 Digital Camera
Can't Get Camera off Standby
may be the rec mode button is set at the anti grounding..usually at sony camera there are 3 switch mode the 5 sec mode, anti grounding and other and always use is the start and stop mode...this switch is located at the side of the camera...
Aug 26, 2007 | Sony Handycam DCR-TRV10 Mini DV Digital...
Fuji FinePix A345 Digital Camera Logo
136 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
