Question about Texas Instruments TI-84 Plus Calculator
Delay in clearing screen; also delay in number appearing after entry
  • 9 Answers
The same thing happened to me. I found somewhere that the no/slow key response could be due to a short in the I/O socket. I blew into it really hard, and it works perfectly now!!!!! I hope this helps.
Posted on Sep 13, 2008
Nokia C6-01 How do I delete single dialled or received calls from the Log? I can delete from the dialled screen but the call remains in the Log.
Hello Sinyoro,
In the Call Log eg. Dialed Numbers, highlight the number/contact you want to delete, press "Option" and then select "Delete", this will delete only the selected entry. Make sure you don't press the "Delete All".
Hope this helps.
Thanks.
Jan 01, 2018 | Cell Phones
How to change time and date
Follow this procedure to set the current date and time.
1. Open all three one-touch speed dialing panels.
2. Press [Data Registration]
3. Press [up arrow] or [down arrow] until <TIMER SETTINGS> appears, then press [Set]
4. Press [up arrow] or [down arrow] until <1.DATE/TIME SETTING> appears, then press [Set]
5. Register the current date and time using the numeric keys. Use 24-hour notation to enter the time (eg. 1:00pm as 13:00)
You can also press [>] or [<] to move the cursor without changing a number entry. To restore the previous entry, press (c) (clear)
6. Press [Set]
the message<DATA ENTRY OK> appears on the screen for a few seconds.
7. Press [STOP] to return to the Standby Mode.
May 13, 2011 | Canon MX700 Office All-In-One InkJet...
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
I am trying to figure out how to set the scanner frequencies
  1. Press hold then enter then enter the channel number where you want to store a frequency. Then press "FUNC" and "PGM" and the channel number will appear.
  2. Use the number keys to enter a frequency including the decimal point you want to store.
  3. Press "E" to store the frequency into the channel.
  4. Note - If you entered an invalid frequency in step two "ERROR" will appear and it will beep three times. Enter a valid frequency.
  5. The scanner automatically rounds the entered number to the nearest valid frequency. ie an entry of 155.174 will automatically be rounded to 155.175
  6. When you enter a frequency into a channel, the scanner automatically turns on the delay function and "DLY" appears. When delay is turned on the scanner automatically pauses scanning.
Mar 19, 2011 | Uniden BC72XLT Handheld Scanner
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
Time delay between pressing remote and reaction on screen
stevec795
Do you have fresh batteries in the remote? Drained batteries can cause the delay problem. If you do have fresh batteries, then you will need to readdress the remote to the receiver. I have provided instructions on readdressing the remote. I hope this helps.
Remote: All Other Remotes
  1. Go to System Info screen
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Ray Calo
DISH Network
May 09, 2010 | DISH Network IR Remote Control
How do i clear the L1 L2 so on cells?
I do not understantd what you mean by the so on cells words.
1. To clear all lists
Press [2nd][CATALOG] to access the list of commands. Scroll down till the fat right arrow point to ClrAllLists. Press [ENTER][ENTER] to execute the command. Screen displays Done.
2. To clear the list L1 completely
Press [STAT][4:ClrList]; command echoe on main screen as ClrList . You must specify what list you want to clear. To clear L1, you insert at the place of the cursor L1 and press [ENTER]. But to insert L1, you press [2nd][1] (L1) and press [ENTER].
3. Clear L1 and L2 completely you do as in point 2.
Press [STAT][4:ClrList] [2nd][1] [,] [2nd] 2 (L2). On screen command appears as ClrList L1, L2. Press [ENTER] to execute it. Screen displays Done
4. To clear a number in a cell.
Press [STAT][1:Edit]. The list editor opens. Move cursor to the top of the list, say L1. and highlight the heading
The whole list appears on the commande/edit line.
Press [ENTER].
Cursor moves to the entry line where all elements on the list appear between { }.
Use the cursor to the value you want to remove and press [DEL]. Do not leave unneeded commas.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
90 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
