Question about Jenn-Air Dishwashers
We have and old jenn-air dishwasher DW860uqp and need to change the filters. How do you do this? -
SOURCE: I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Posted on Jun 03, 2008
  • 338 Answers
SOURCE: JDB1100AWS not rinsing
if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
Posted on Jan 11, 2009
  • 297 Answers
SOURCE: My Jenn-Air dishwasher has sprung a door leak! :-(
it's just a door gasket,you might still find it a appliance repair place.
Posted on Jul 15, 2009
VtToolMan
  • 704 Answers
SOURCE: Jenn Air dishwasher door won't close
It could be as simple as the mounting tabs being too tight up against the bottom of the countertop. You might need to loosen the 2 screws that hold the dishwasher in place against the underside of the countertop, until the latch and strike plate engage.
It might be that the countertop is interferring with the latch or that the door edge doesn't have enough clearance to properly close and engage the latching tab.
If you can't get the latch to engage, it might be that it got bent slightly in the removal and reinstallation. A simple way to confirm this would be to pull the dishwasher out about 4-6" from the cabinet and see if the catch and latching tab line up and engage. If they do, then you need to make sure there is enough clearance around the cabinet edges and at the underside of the countertop. If it doesn't engage, then it is more likely that the tab (male part) needs to be adjusted slightly to allow for proper engagement. Make small adjustments (bending carefully up or down until it goes into the latch without binding.
You should be able to get this lined up with a little effort and have things working again.
Hope you found this Very Helpful and best regards!
Posted on Aug 18, 2009
Testimonial: "The advice got the door moving better, but I appears that the latch is broken and will have to be replaced."
  • 11 Answers
SOURCE: i have a jenn-air dishwasher, at least 11 years
make sure the drain line is clear all the way through. also check the drain itself at the bottom of the wash area. They can get clogged there if large amounts of food or other objects get stuck on the grate. If it is not a clog issue, it is probably the pump. After 11 years I would not be surprised to see a pump let go. A pump replacement may or may not be worth doing. With the machines I work with it is more cost effective to replace the entire machine. I hope that isn't the case with you.
Posted on Dec 16, 2009
Testimonial: "thanks for the quick reply. These were good suggestions, we giggled the drain tubes, which either loosened glog or an ice jam. "
Dishwasher installed correctly? One year old jenn air dishwasher leaves brown **** and water film on plastic components inside, rinse agent used regularly
you must contact to jENN-aIR FOR get customer support, about the material recommend. About some agent used, or if some bad design material from factory.
God bless you
May 09, 2012 | Jenn-Air Dishwashers
My Jenn- Air dishwasher (2 years old) used to clean great but now it is leaving a white film on the dishes and there is often residue left in the glasses as if it is rinsing with the dirty water. I can't...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 20, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
"change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Mar 05, 2010 | Jenn-Air JCB2059G Bottom Freezer...
Jul 14, 2009 | Dishwashers
Smell in a new dishwasher
run bleach through it. if your on well water then this will happen often
Jun 22, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jan 11, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn air quiet series II dishwasher has blinking light on clean and light wash after it runs...it only goes away when we push the off button...it didn't used to do this
Couple of things to check: there's a float that needs to more freely, make sure it does. There's dishwasher cleaning instructions in the operation manual. You may need to take the lower rack out, take off the spray arm to get at a filter, which you should clean and replace. Then you can try to run some white vinegar through a wash cycle. Jean Air has these instruction at their web site.
Oct 05, 2008 | Jenn-Air Dishwashers
Jenn-Air dishwasher: error code C2 and C1
This is not a JDB6510 Model. Check the inside label when you open the door.
Sep 09, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwashers Logo
59 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
