Question about Haier Heating & Cooling
Haier Portable A/C HPPRO9XC7 will not turn on shows E1. Unit is only 15 months old and has worked well until now. Factory suggest STUCK button -- OK -- HOW do you unstuck a buton.
    President:
  • 1,263 Answers
You can just take the panel off to the control and look for dirt and grime. then take a can of compressed air that you can by at a local hardwar store or office supply and blow around the buttons. also you can unplug the unit and let it reset itself sometimes this will break the circuit to the button and then it should work normally. you can also tap on the button(just enough that it will click like tapping on a window) these should help you...please rate thanks
Posted on Sep 04, 2008
  • 13,433 Answers
Hey, do you have the remote? try using the remote. to unstuck a button.. well check the buttons, the ac may only think a button is stuck when its actually not. have you tried unplugging for a while?
(E1, failed keystroke circuit / stuck button)
    Genius:
  • 1,447 Answers
Hi-
You will have to open up the unit and check on the filters for dust and on the control panel area, check the membranes on the airconditon panel or the button, clean the dirt surrounding it as well.
keep us posted
    Master:
  • 521 Answers
The e-1 error means servicing is required as something is blocking the ventillations.
pls do rate the solution
thanks.
regards.
fixya expert team
  • 42 Answers
Http://www.haieramerica.com/en/
Posted on Jul 06, 2011
Ac won't turn on after cleaning and E1 appears on control panel
E1, The e1 error code could mean multiple things. The most common fault with the unit is a stuck button on the access panel. Gently push each button in and out to ensure none of them are stuck. The panel may have malfunction due to moister. See that the unit is installed properly, and then leave it off for a few hours so the moister can dry up. if these two things dose not work then the temperature sensor could be bad. Heir 1-877-337-3639
Oct 01, 2014 | Haier 5200 BTU Window Air Conditioner...
What to do to fix the E1 error on a haier her08xc7
Push buttons about five times each beforjust to make sure they are not stuck....then......Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. See the Care and Cleaning section in your use and care manual. After cleaning, replace the filter and plug the air conditioner back in.
Other forums say the E1 code is because the AC thinks a button is stuck or because it's dirty, but almost all of them say to use the remote and it'll work ok.
Jul 23, 2012 | Haier HWR08XC7 Air Conditioner
My ac is showing an E1 code. what can be done to solve this problem?
Unfortunately, there's not much you can do. The E1 error code indicates a sensor shutdown. However, you can try turning the unit OFF & unplug it for 15 minute. Then plug it back in and turn it ON. If the electronics reset and reverted back to the original factory setting, you can set the controls as you like.
If you continue to get the E1 error code,, contact Haier Customer Support 1-877-337-3639.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Haier ESA3125 Wall/Window Air Conditioner
WHAT IF HAIER AIRCONDTIONER SHOWING E1,AND IT STARTED GOING TO DIFFERENT TEMPERATURE WITH OUT REMOTE OR TOUCHING,
You must have a stuck button. When it is first turned on it checks the keyboard circuit and if the test fails the E-1 shows up.
Jul 16, 2011 | Haier HWR08XC7 Air Conditioner
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
E1 error code displays when unit is plugged in
I just had the same problem no an hour ago. E1 showed on display, and none of the buttons on the AC worked, not even the power button.
SOLUTION:
In the past, I've noticed that my universal remote sometimes changes something on my AC when I'm trying to change something on the VCR. (My AC is in the living room.
Well, I saw that the buttons on the AC wouldn't work no matter what I do. So I go get my universal remote, press the DVD/VCR mode button at the top, then just start pressing random buttons until something happened. I've got it now. I can control everything on the AC with it:
The remote is a 'One For All' URC-3021B00
The buttons are as follows:
rewind=power on/off
pause= timer on/off
4=low/high
5=temperature up
9=temperature down
8=fan/cool
Here is the remote:
http://www.oneforall-na.com/remote.php?type=URC%203021
Hope this helps.
May 31, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
423 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
howard thompson
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
