Question about Carrier 38CKC036 Air Conditioner
Inside house is warm
They put 2 months ago(freon) they dont tolsd me their is no leak my house is new 2 years old after two years i put 78 the thermostat and 81 inside the house it takes 40 min. b4 it went down to 80 .[please help me i went ouside and i put my hand on top of the fan its not warm air buit my fan is working good. my aircon is small my house is one story 1600 sq. feet
    Problem Solver:
  • 8 Answers
It may not have been charged right. Make sure the filter is clean. I would call the ac company back and ask for someone more knowledgable to come out.Tell them it still is not cooling right.
Posted on Oct 31, 2008
  • 1,420 Answers
Use the spell check and please restate your issue. Have you checked your air filter? Has the unit been serviced recently?
Posted on Oct 21, 2008
Unplugged fridge 9 months and now it doesnt cool at all
it's 20 years old,replace it,don't waste a penny into that machine,most likely you have a problem in the sealed system compressor and freon so don't waste any of your time or money.good luck,if you say the compressor and fans are running and it's not getting cold one of the lines could have rotted out and the freon gas leaked out,you can remove the back inside wall of the freezer and look at the evaporator coil,if it's running fine you should see an even frost pattern covering the coil,if you only see frost where the lines connect to the coil you have a freon leak but i wouldn't even waste my time doing that on this machine just repace it.
Jan 01, 2014 | Refrigerators
My a/c is blowing warm air. its a new house; moved in just a month ago. my grandmother constantly changes the settings back to 80...could this have busted my a/c?
Dear Sir:
1) Could be a reason just moving the thermostat.
2) You need to check the unit for condenser + evaporator very well from a Tech. Since the freon is not good signal for a good operation , the reason is may be some Leakes in the pipes.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 29, 2012 | Heating & Cooling
Blowing moteratly warm air
SOUNDS LIKE YOU ARE OUT OF FREON. A LEAK OR SOME KIDS SNIFF THE FREON. OLD ONES TAKE FREON 22 NEW ONES MAY TAKE 410A
Apr 20, 2010 | Mitsubishi MS-A09WA Split System Air...
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Kenmore tx5300 less than 2 years old ice on outside pipe system trying to cool down, system set at 70 house inside temp 78 led light on inside system says operating normal could it be lines plugged out if...
The lines that are frozen are not ones you can run bleach through. The best way to troubleshoot this one is to first turn off the unit and put it fan only mode to thaw and de-ice the coils. Then check the air filter to be sure that it's clean and that there's nothing blocking the air flow. If the filter is clean then you should check the coils just beyond the filter. Check to be sure that the coils are clean and free of dust and debris. If the coils are clean then you may be low on freon. At this point it does require a certified A/C technician to leak test and charge the system. These are the problems that would cause your unit to freeze up. Hope this helps, good luck!
Sep 01, 2009 | Kenmore Heating & Cooling
A month ago my a/c started to leak water.We called help & they pumped the tubes then they put freon,they said the leak is on the unit not inside the house,it worked for a week then the a/c stopped...
Could be leak on your indoor coil and they missed it. Call them back ask them to leak check inside. If they missed it it is their rsponsibility. to repair. Rus
Jul 19, 2009 | Heating & Cooling
2001,4.0 jeep wrangler air conditioner blowing warm
You have a leak in the AC system, have it tested and repaired.
Jun 07, 2009 | 2001 Jeep Wrangler
Air conditioner compressor
Fix the ac freon leak and put freon back in. When you get enough pressure in the system the compressor will come on. Go to another garage and see what they tell you.
Apr 25, 2009 | 2002 Isuzu Rodeo
Carrier 38CKC036 Air Conditioner Logo
101 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
