Question about Kenmore 4292x Front Load Washer
Washing machine has intermittent drain issues with F02 code
My washer (He3t) front loader started making an unusual sound when it started to drain. It never would drain the water and the pump ran for a long time, eventually ending in an F02 code. I kept messing with the buttons and unplugging/re-plugging in the washer, and finally got the spin/drain cycle to drain the water down. However the clothes still had soap in them so I ran the rinse/spin cycle. Once again the drain cycle made this unusual sound and wouldn't drain. I suspect its the pump. I removed the back panel, but the pump appears to be closer to the lower front panel. I have three screws at the bottom of this front panel that I removed, but couldn't figure out how to get the panel off after that, it appears something at the top of that panel is still holding on. How can I get this panel off? We just recently stacked the dryer on top of this washer, so I'm hoping you can tell me how without removing the dryer! Thanks in advance
When the three screws are out of the bottom, you should be able to pull the front panel down (towards the floor) and then out from the bottom. Unscrew the big white cap on the drain housing. Be prepped for the water. Most of the time the problem is due to **** in there.
Posted on Sep 24, 2008
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
HE3T WILL NOT GO INTO SPIN PUMP TAKES A LONG TIME KEEPS SHOWING A CODE OF F02
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Kenmore HE3T Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Getting an 02 F flash
F02 Long Drain
Potential Causes
Aug 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F2 code... stops part way through cycles.
Potential Causes
Jun 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 4292x Front Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
