Question about Texas Instruments TI-83 Plus Calculator
Cutting off My calculator keeps cutting off for no reason. One time I pressed the left arrow button and I cut off. I've changed the batteries, then I tells me to install the software. Can you help me?
  • 32 Answers
The cutting off thing i have no idea. I would assume you calculator crashed maybe due to lack of memory or ram. When you changed the batteries you probably hald the del button and it deleted your operating system so you need to get a new one from the computer cord or just ask a friend to send you one.
Posted on Sep 18, 2008
Keeps cutting out and wont start
Try changing the solenoid switch of your starter. check your battery too... it might be time to change it depending on how old your bike is.
Nov 07, 2013 | 1995 Honda VFR 400 R NC30
My system volume just keep cutting off and I can't find the stereo button
Press all the buttons you can find , one of them is the volume button.
Jan 21, 2013 | Audio Players & Recorders
I have changed the back up batteries as well as the AAA batteries in my TI-83 and it still isn't cutting on...is it broke?
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Jul 26, 2011 | Texas Instruments TI-83 Plus Calculator
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
What i am projecting is cut off
Yes you can cut off you projection there is three ways to cut off.
1. there is a button on the projector name "SHUTTER" press the shutter to topping the projection temporary.
2. One same button on remote control "SHUTTER"
3. and the same function you can use with in menu of projector
press MENU button use LEFT and RIGHT arrow buttons to select "OPTION" press one time DOWN arrow button to select the SHUTTER press ENTER.
(for re-projection just press again SHUTTER button from remote control or projector key pad or through menu)
Jan 17, 2011 | Panasonic PT L735U Multimedia Projector
My Dyson DC04 Keeps cutting out after a period of time
check the bottom left hand corner, there should be a yellow button, that could be open, when it's open it, it won't ****
Jun 30, 2009 | Vacuums
LOADING NEW PAPER
HOW DO I LOAD PAPER INTO THIS
Aug 10, 2008 | Canon P23-DHIII Calculator
Paper Loading
Cut a diagonal to make a sharp corner on the end of the roll, then stick the corner into the paper slot, and then press the feed button.(arrow on top left)
Oct 18, 2007 | Canon P23-DHIII Calculator
Loading paper
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Texas Instruments TI-83 Plus Calculator Logo
46 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
